WW II Radial engine mounts
Posted by mandrake on Tuesday, January 20, 2004 2:11 PM
Hello Fellas! does anyone knows where can i get some pics of the engine mount on a B-17 and on an A-26? i want to scratch build those but i havent been able to find nothing on the web so please any reference that you may provide will be helpful, by the way, the models that i am working on are on 1/48scale
Dead [xx(]Dead [xx(]Dead [xx(]
Thanks!
my best regards
Mandrake
Thanks! My Best Regards Hector Reymundo
    November 2003
Posted by shrikes on Tuesday, January 20, 2004 2:54 PM
Hey, mandrake! what exactly are you looking for, pictures of the engine cowling removed as if it was being serviced or pictures of the plane without the engine, like it was being replaced. I don't know if i have any of the latter, but who knows what I'll turn up. Smile [:)]
Blackadder: This plan's as cunning as a fox that used to be Professor of cunning at Oxford University but has now moved on and is working with the U.N at the high commission of cunning planning
    December 2003
Posted by mkee on Tuesday, January 20, 2004 3:49 PM
I have a few good details of the B-17 eng mount that shows how it was constructed.Also shows good detail of exhaust around the mount.I'll try to scan them off for you.I also have good drawings of all the various ribs,spars and other internal structures if your interested.I don't have anything on the A-26 yet but I'm looking.
Posted by Ashley on Tuesday, January 20, 2004 4:06 PM
Here is a website about a group in Cincinnati restoring a B-17E. There are many wonderful detail photos on that site.
http://www.ultimatesacrifice.com/
Have you flown a Ford lately?
Posted by mandrake on Tuesday, January 20, 2004 10:08 PM
hey shrikes!, i am looking for pics of engines without cowling and also the way the engine was mounted on the plane, i have modeled the R-2800 engine for an A-26 but i dont know how the mount was on this one neither on the 1820´b-17 engine, so if you or someone else out here can help me with any reference regarding the engine mounts will be appreciated.
Hey mkee! yes i am interested in any reference you can provide, drawings pics, anything, i really appreciate it, and dont worry about the A-26, if you can help me with the B-17 thats more than enough.
Thanks a lot
Regards to you all!
Big Smile [:D]
A-26 Help
Posted by Anonymous on Wednesday, January 21, 2004 12:02 AM
Hector,
Seems that we're working on similar projects, so perhaps we can directly share research. I've got a few pics of the A-26 engine mounting and exhaust. They're 'service stand' photos from either USAF training or from the field in Pusan Korea. I won't have a chance until tomorrow night, at the earliest, to get them posted up, but I'll get them to you as soon as I can.
Best of Luck,
Jamie
Posted by mandrake on Wednesday, January 21, 2004 8:30 PM
Dont worry Jamie, i am not in a hurry so take your time, i also have some pics of the A-26 that may be useful for you, thanks in advance!
BTW my e-mail is hreymundo@yahoo.com
(i will be out of town for a cupple of days and i may not be able to answer til monday) Blush [:I]
my best regards
Hector.
Cool [8D]
    May 2003
Posted by qmiester on Wednesday, January 21, 2004 8:32 PM
Mandrake,
I've been lucky enough to work for an outfit that operated both the A-26 and the B-17 as air tankers. Every time you look at the A-26 engines, you're looking at the engine mounts. The area between the cowl flaps and the leading edge of the wing is the engine mount. If you have it off the aircraft, without engine installed, it looks like a large inverted punch bowl. The engine is secured to the mount with 1/2 in bolts torqued to 1300 in lbs. The quick change unit (engine and mount) is secured to the wing with 3/8" bolts torqued to 150 in lbs. Before installation all the accessories and wiring are installed in the mount. Once installed, you spend a couple of hours hooking up hoses and wiring. 2 guys (who are familiar with the installation), can start draining the oil and five hours later have a new engine installed and be hitting the starter. (Been there, done that, got the T-shirt). Its really a nice installation for a radial.
The B-17 had a typical 30's engine mount - before removing the engine from the wing, you had to remove all the cowling and panels, remove all the accessories and disconnect all the wiring and hoses. You could then either remove the engine from the mount or remove both engine and mount from the wing (the latter is a heck of lot easier). You turn the engine and mount horizontal and set on the floor. Pull the engine from the mount and then reverse the process. The whole thing would usually take a couple of days to accomplish (less if you worked straight thru). I read somewhere the the record for changing an engine with this type of mount system (which is what all other radial systems in the US inventory used) was 8 hrs by a specially picked team of B-25 mechanics of the 22nd BG in the SWPA.
The mount its self is a circle made of 1 1/2" tubing about 2 1/2 ft in diameter (measure the tube the engine cylinders are on in your model. the circular tubing should just slide on over it at the back). It was attached to the fire wall with four legs, not sure how long they were, but when the mount was setting on the floor it stood about 3 ft tall. The legs angled out from the circular mount to 4 points just inside the skin of the nacelle at the fire wall.
Hope this helps a little.
Quincy
A-26 Engine Pics
Posted by Anonymous on Friday, January 23, 2004 10:32 PM
Sorry this is late, but life can be interesting at times.
I've posted some of the pics I have in electronic format to the following location:
http://www.frontiernet.net/~biod/Images/a26/
I've pulled these pics from sites all over the web, and I hope you find them useful.
I do have some additional photos that my dad took while in Pusan, Korea in 1952-1953,but I haven't had a chance to scan them, yet. I'll try to get to that this weekend, so that I can post those pictures as well.
Best of Luck,
Jamie
    January 2003
Posted by Jeff Herne on Saturday, January 24, 2004 12:38 AM
If you need R-1820 detail photos, let me know...I have one. This is a distant shot of the motor, but I'm not back in the office until Monday.
Jeff Herne
Director, NJAHOF
www.njahof.org
Posted by mandrake on Monday, January 26, 2004 10:51 PM
Yes please Jeff, i will really appreciate any help you can provide, all the detail i can get from your engine will be very very helpful for mine, thanks a lot and i hope you can get the shots for me.
    January 2003
Posted by Jeff Herne on Monday, January 26, 2004 11:10 PM
Was out of the office today, will photograph it on Tuesday and post the pictures here:
www.njahof.org/models/jeff_index.htm
In the meantime, you can look at my models!! :-)
Jeff
Posted by mandrake on Tuesday, January 27, 2004 11:35 AM
Wow!, great models Jeff, congrats! and dont worry take your time, i will be waiting around your site Wink [;)]
regards
Hector.
Big Smile [:D]
    January 2003
Posted by Jeff Herne on Tuesday, January 27, 2004 1:44 PM
Day two of freezing rain, even the dog doesn't want to go outside...looks like with the 6-12 inches of snow coming later today, that it'll probably be Thursday at this point before I can get the 1820 pics posted.
Jeff
Posted by mandrake on Tuesday, January 27, 2004 2:33 PM
What? how come?? where do you live?? freezing rain??? here in Mexico City the weather is warm and sunny, i have never been in a situation such as that, i wouldnt be able to survive!! oh my God! freezing rain!!! :-(
My best regards
Hector.
    December 2003
Posted by mkee on Tuesday, January 27, 2004 10:11 PM
Sorry about the delay.I had to get a new scanner and seem to be having trouble getting it to work.I have a friend that's going to try to beat this box of silicon in to submission for me.Hope to have the scans for you soon.
Mkee
    January 2003
Posted by Jeff Herne on Tuesday, January 27, 2004 11:41 PM
Hi Hector,
I'll trade you an R-1820, 12 inches of snow over a 1" layer of ice, and -5 degree for a week in sunny Mexico...
I'm in NJ, about 45 minutes from NYC. Yup, it's still snowing outside...has been for the last 6 hours.
Jeff
Posted by mandrake on Wednesday, January 28, 2004 11:02 AM
mmmmmmmmm........ let me think....... mmmmmmmmmm....... sorry to disappoint you Jeff but i am pretty sure i wouldnt be able to make it, i have never been in a situation like that... you see, i am a pilot, and the owner of the plane sells boats and yachtes, actually the company´s name is PERFORMANCE BOATS so i fly him only to beautiful beaches, not only in Mexico but also in the US so with such a background now you can be sure that if i go to NJ i will defenetly freeze myself off, but in the mean time if you want you are invited to the sunny Mexico City, or Acapulco, or even Cancun, just let me know and you can have a great time in a warmer situation!
My best regards Jeff
and thanks
Hector.
Posted by Fabio Moretti on Wednesday, January 28, 2004 11:30 AM
Hi Mandrake, some pics of R-2800
http://www.enginehistory.org/G&jJBrossett/R-2800%20Double%20Wasp%20on%20P-47.JPG
Next on the workbench
Posted by mandrake on Wednesday, January 28, 2004 12:57 PM
Agradece muito, mim não falam o português mas eu tenho quis sempre aprender, isso pic na ligação sou awesome onde você o começou? se você tiver algum mais pics que você quer compartilhar me deixa saber, aquele o pics está indo ser muito útil. obrigado.
minha mais melhor consideração
Hector.
PD. haber si le entiendes :-)
A-26 & R2800 Info
Posted by Anonymous on Wednesday, January 28, 2004 5:17 PM
Hector,
I've been down sick for the week. (darn flu bug!) So, I've not had a chance to get the scans done for you.
Here is a partial list of my sites for A-26 and R2800 pictures. (IMHO these are some of the best I've been able to find)
Engines at the A.A.M. -- Pratt & Whitney R-2800 <http://www.arkairmuseum.org/doublewasp2.html>
Corsair Pratt & Whitney R-2800-8 18-cylinder radial engine by Fine Art Models <http://www.fine-art-models.com/e/model/aircraft/corsair/thumbsPW.htm>
Some great up close shots of the R2800, but none of them are specific to the A-26:
http://www.aircraftresourcecenter.com/AWA1/301-400/walk374_PnW_R-2800/walk374.htm
http://www.aircraftresourcecenter.com/AWA1/301-400/walk375_PnW_R-2800_8w/walk375.htm
http://www.aircraftresourcecenter.com/AWA1/201-300/walk258_Radial_Engines/walk258.htm
These are just good A-26 photo sites with lots of good detail information:
a-26b.html <http://www.philsaeronauticalstuff.com/a-26b/a-26b.html>
Historical Aircraft Squadron <http://www.historicalaircraftsquadron.com/phase.htm>
A-26 Invader War-eagle museum <http://www.war-eagles-air-museum.com/a-26_1.html>
Bueno Suerte,
Jamie
Posted by mandrake on Wednesday, January 28, 2004 7:27 PM
Thanks Jamie, very helpful sites, i have e-mailed you, hope you are doing better!
saludos y gracias por la ayuda!
Hector.
Posted by Fabio Moretti on Thursday, January 29, 2004 5:13 AM
Hi Hector, I undrstand you...try to use the Google, is the best...after you find the subject go to "images" and you´ll be able to see some pics of the subject that you choosed...
I started in ´69 with the aid of my father (I was only 8 years old)...I started mounting cars, planes and armoured cars, today I mount almost everything (except cars and sci-fi).
I´m sorry but my English isn´t very well...
Regards.
Posted by mandrake on Friday, January 30, 2004 10:42 PM
thanks a lot man! really appreciate it!
Approve [^]Approve [^]
    January 2003
Posted by Jeff Herne on Tuesday, February 3, 2004 2:01 PM
Haven't forgotten ya, but I haven't been back in the office in almost a week.
Jeff
Posted by mandrake on Tuesday, February 3, 2004 6:06 PM
not a problem man! i will keep waiting thanks for the advise!
regards
Confused [%-)]
Zzz [zzz]...
Sign - Dots [#dots]
