1:48 Halifax build
    August 2009
1:48 Halifax build
Posted by rangie on Saturday, March 19, 2011 4:08 PM
Why build a 1:48 Halifax?
Well, as a youngster I played on a derelict airfield that my dad had actually helped to build before he went off to the war.  Just recently I discovered that for almost the entire war it was the base for Halifax squadrons.  So I thought a tribute was in order... I like to build in 1:48 and found i could only get a Halifax in that scale (as far as I know) as a vac formed kit from Fonderie or Sanger.  As the Fonderie kit is a wallet busting price I went for the Sanger.  Now, what you need to know is that I have never, ever, built a vac formed kit before!  So here is my story!
Here is the kit out of the bag and its a big boy!Photobucket
[View:/themes/fsm/utility/
so now to the first stage cutting out the fuselage..not so painful!
Photobucket
Then I began to add the inner struts and longerons
So far so good!  I shall keep you posted as the build progresses!
[View:/themes/fsm/utility/Photobucket:550:0]
Edorc
    August 2004
Posted by toomanyslurpees on Saturday, March 19, 2011 4:24 PM
The Fonderie kit is injection molded but is also a bear to build, certainly no easy 1:48 Halifaxes, looking forward to seeing the progress on this one. I have the Sanger Stirling but haven't made it too far on that.
    April 2015
Posted by spadx111 on Saturday, March 19, 2011 4:55 PM
a very intersting build.
Ron
    August 2009
Posted by rangie on Monday, March 21, 2011 12:11 PM
Have now completed the cockpit area.  The kits  flight engineers and flying instrument panels were hopeless so I raided my spares box. Also the wireless operators and the navigators stations had to be scratch built.  You only get the pilots seat with the kit so again spares box raided!  Have worked on the wheels and main landing gear ( which had a lot of flash to clean up)  Getting the tyres into the landing gear was quite a struggle!  Currently working on the inner engines and trying to work out how to create the u/c doors.
Here are some photos of work so far.
Cockpit area
[View:/themes/fsm/utility/Photobucket:550:0]Photobucket:550:0]:550:0]
Edorc
    February 2011
Posted by Reasoned on Monday, March 21, 2011 2:33 PM
Wow does that look like a lot of work, good luck.  I must say, between the Lancaster and Halifax those British WWII bombers were... boxy.
Science is the pursiut of knowledge, faith is the pursuit of wisdom.  Peace be with you.
On the Tarmac: 1/48 Revell P-38
In the Hanger: A bunch of kits
    August 2009
Posted by rangie on Tuesday, March 22, 2011 10:02 AM
Got to agree, even on the tarmac the pilot was 22ft off the ground !!
Edorc
    April 2015
Posted by spadx111 on Tuesday, March 22, 2011 12:05 PM
so far so good can't wait to see the finel outcome one this build
Ron
    September 2009
Posted by B17Pilot on Tuesday, March 22, 2011 1:44 PM
Looks good, I'll be following this one.
