US WW2 Bomb Color Changeover Date
    September 2005
Posted by richs26 on Wednesday, May 18, 2011 1:45 AM
I have a question about when did the US change over from the yellow color used on bombs pre-war to the standard OD color used during the war?  I was watching Clark Gable's film about the 351st BG, and the ammo guys were loading yellow 1000 lb'ers in 1943.  And what was the color used, insignia yellow, the same used on prop tips and serial numbers?
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
Posted by Anonymous on Wednesday, May 18, 2011 5:43 AM
I thought the yellow was reserved for only practice bombs, which were inert...?
    February 2011
Posted by MAJ Mike on Wednesday, May 18, 2011 6:37 AM
Manstein's revenge
Hmmm.  I've seen blue-colored practice/inert ordinance.  Guess that's from a later date.
 "I'd "I'd rather be historically accurate than politically correct."
"Sic gorgiamus allos subjectatos nunc!"
    June 2008
Posted by Hans von Hammer on Sunday, May 22, 2011 7:13 PM
richs26
 11 March 1942
Yellow Bombs manufactured prior to that date were "ert"...
Overall (no adjective) Yellow  with black manufacturer's markings. It wouldn't be uncommon to find Yellow bombs in places after that date, since the ordnance would still be in the colors that is was painted with when it was made, so bombs with yellow bodies in 1943 would still be quite plentiful, as they weren't repainted after they left the manufacturer.. BTW ,  Whenever the US Military changes ammo color codings, they always make up a GTA (Graphic Training Aid) that includes both the new and old markings, just to avoid the possibility of some Snuffy getting it wrong...
 U.S. BOMB, 1,000-LB, DEMOLITION HE, AN-M44, AN-M65, & AN-M65A1
General Information
The fundamental characteristics of Army "M" Series bombs are: Parallel sides, ogival nose, and boat tail (box type-tail assembly construction); and filled with 50/50 Amatol sealed at both ends with TNT surrounds. Some are now classified as obsolescent.
 The Army-Navy "AN" series is similar to the "M" Series, except: (1) Third suspension lug added at center of gravity and 180 degrees removed from other two lugs, and (2) base plate changed to the male type. Since the development of the "AN" series, there have been two further modifications of the general-purpose (G.P.) bombs within that series, successively the "AN-G.P." and "AN-G.P.A1" modifications.
 Prior to the organization of the AN Standardization Board in 1941, these bombs were designated as "Demolition H.E." bombs; under the standardization policy they were retitled as "General-Purpose High-Explosive (G.P.H.E.)" bombs.
I think you'd be safe with plain ol' "Paint, Yellow, Flat, Enamel, Testor's, 1/4 oz, #1169 "... Or whatever other brand you chose..
Keep in mind though, that different bombs had different colors overall, OD, Grey, and Blue being the primary body colors.  OD denotes High Explosive, Grey, Chemical, and Blue,  Practice. The bands and markings could be green, red, yellow, white, black, or purple...
