spray paint nozzles
spray paint nozzles
Posted by Anonymous on Saturday, March 8, 2003 7:53 PM
I like using spray paint as much as possible. You can't really do detail work with spray paint like you can with airbrushes. I was thinking what if you enlarged the hole on the nozzle that the spray paint come out of. Would that make it possible to paint fine lines?
Posted by Anonymous on Saturday, March 8, 2003 8:28 PM
Becareful of changing the nozzles of spray cans. What will happen is that you will change the flow of the paint leaving the can. this means that the paint will be very difficult to control leading to runs. Also if the nozzle is to big the paint will no longer atomize. That means that the paint would flow in a constant stream. Air brushes are becoming very inexpensive and you can use can air if you can't afford an compresser. You will find that the more you use the airbrush the wasted paint you have with canned paint.
Good luck
Posted by Anonymous on Saturday, March 8, 2003 10:03 PM
Maybe someone will invent a narrow spray nozzle. I'd buy one.
Posted by Anonymous on Wednesday, March 12, 2003 10:58 PM
One thing that can be done is to use a siringe , plug the sharp side into the nozzle... this should give you a finer line
