QUOTE: Originally posted by plum1030
Mike, haven't you finished that F-15E yet? You posted pics of the exhaust a while ago. You must have something like my schedule.
Hey Karl. How's it going?
It's been a nightmare on the intakes of that F-15E.
The white inside the intakes didn't come out well with the MM acrylic white.
I should have just used MM enamels as that is what I have always used with good results. Oh well, I'm a daredevil. LOL
It started out alright but after getting back into the intakes further I started getting a sandy finish for whatever reason and so I tried to smooth it out with about 5 coats of Future which didn't work. I stripped the paint the other day with Easy-Off which also took the putty out of the seams I had filled so I am back to square one.
My son said I should build something else at the same time and so he went out in the garage to my small collection of kits and brought in my Monogram 1/48 A-1H Skyraider and said, "This would look awesome if you built it" and so I started on it also.
I don't work on them every day either so that also slows down the process.
“Wisdom is the right use of knowledge. To know is not
to be wise. Many men know a great deal, and are all the greater fools
for it. There is no fool so great a fool as a knowing fool. But to know
how to use knowledge is to have wisdom. " Charles Spurgeon
