It's taken a little longer than I thought to post another update!
I blame it on being on holiday for 10 days in Dorset.
Anyway, since my last post I've made a fair bit of progress..
The homebuilt splitter went in OK, as did the pit, with a bit of Blutack for ballast.
As noted previously the fit of the wings was not great either with the upper and lower sections, or their attachment to the fuselage.
Note the amount of filler!
...I got the fuselage together without any major need for filler, just a touch of Mr Surfacer here and there.
I also drilled locating holes for the rear stabs.
This added some strength to the butt joints once the brass wire was inserted.
The fit of the wings to the fuselage was poor, and I ended up cutting off the mounting tabs and sanding the wing flush.
Even so I ended up with a fairly decent fit on top, but with the need to insert strip styrene into the lower joints.
Once everything was together and re-scribed, time for a guide coat of flat black to show any imperfections, and there were lots, which I then had to go back and correct.
The canopy took a fair bit of work with Mr Surfacer to fair it in, and more annoyingly the forward section cracked as I masked it up!
Once I was happy everything was as good as I was going to get it, time for a coat of gloss black.
This was polished to remove any obvious imperfections, then a coat of Tamiya Metallic Grey applied.
This was then masked ready for a coat of Tamiya Chrome Silver. As usual I used two shades of metallic to create some contrast in the final paint finish.
Since those photos were taken the model has been decalled and a wash applied.
Hopefully I'll get to post some more pics tomorrow night.
Karl
