Minicraft kits
Minicraft kits
Posted by Bones-coa on Thursday, January 29, 2004 11:09 AM
SoapBox [soapbox]
Whew...I guess I was mistaken. I thought these were very nice kits.
I picked-up a 1/144 KC-97G by Minicraft and I'm less than impressed. The plastic they use is very strange looking...having some form of metal flake in the plastic. Alignment pins are useless, clear plastic is way too thick and I'm about to fight a huge gap between the engine cowlings and the rest of the engine area of the wing. Oh, and the instructions look like a photocopy of a photocopy of a...well, you get the idea.
This aircraft was going to be a quick assembly and test for a NMF. Well, it will definatly be a test!
Thanks for letting me rant a bit.
Dana F On the bench: Tamiya DO335B-2 with LOTS of Aires stuff (On Hold) Trumpeter A-10 with LOTS and LOTS of aftermarket goodies! (On Hold) Tamiya 240ZG (In work)
Posted by Anonymous on Thursday, January 29, 2004 11:31 AM
Makes me afraid to do that MD-80 on my shelf.
Posted by BlackWolf3945 on Thursday, January 29, 2004 11:35 AM
Academy is a mixed lot, I've had kits which have the 'zoxed' instructions like you describe and I've had kits with well-printed instructiions. I've yet to come across the funky plastic you mention, but the levels of detail, accuracy and buildability of their kits are somewhat inconsistent.
This is because some of their kits are totally original, some are reboxings of other manufacturers' kits and some seem to be reverse-engineered from other manufacturers' kits, in part or in whole. Also, they still produce much of their older products and alotta those, original or not, ain't the best out there.
I dunno too much about their small scale stuff like the KC-97, but I do have one of their DC-3's in that scale and it's giving me only slight problems as regards fit and overall buildability.
Fade to Black...
    November 2003
Posted by chopperfan on Thursday, January 29, 2004 12:20 PM
I can't speak for the aircraft mentioned. But, their 1/48 H-60 series of helo's is top notch.
I may catch some flak on this. But I have, knock on wood, so far had very, very little fit or assembly problems. Thumbs Up [tup] Detail is very good and the instructions are top notch. Thumbs Up [tup]Thumbs Up [tup]
But, as I said, this is my only experience with Minicraft kits. My 2 cents [2c]
There is no doubt in my mind that they could very possibly do some bad projects. Nearly every company has.
Randie Cowboy [C):-)]
Randie [C):-)]Agape Models Without them? The men on the ground would have to work a lot harder. You can help. Please keep 'em flying! http://www.airtanker.com/
Posted by Bones-coa on Thursday, January 29, 2004 12:31 PM
QUOTE: Originally posted by blackwolfscd
Academy is a mixed lot...
Heh...did you mean Minicraft? Big Smile [:D]
Posted by BlackWolf3945 on Thursday, January 29, 2004 1:27 PM
Well, yes and no. I always associate Academy with Minicraft because they used to be affiliated as Academy/Minicraft. Minicraft has been sort of a manufacturer/importer/agent (or whatever you wanna call it) over the years for several model manufacturers, including Hasegawa.
They've always had a few of their own products, though. As an example, Minicraft released a 48th F4U-4 Corsair after they and Academy split. Some folks seem to think that this is the same kit as the Academy Corsair. Uh-uh. They are similar, though, and the Minicraft kit looks to be a very poor attempt at copying the Academy kit, but it's a piece of garbage.
Nevertheless, even though Academy and Minicraft have 'parted company' and most folks consider them separate entities, Minicraft still manufactures kits which came out under the Academy/Minicraft label and I still consider the two to be one and the same. That's just me, though... Tongue [:P]
Fade to Black...
Posted by Bones-coa on Thursday, January 29, 2004 2:16 PM
Ahh, ok. Learn something new everyday. Smile [:)]
Thanks.
Posted by Anonymous on Friday, January 30, 2004 12:52 AM
yeah, but where else are you going to find a Piper Cherokee, Piper Cub, Cessna 150, and Bonanza V-tail in 1/45??!! I agree the kits and directions need tuning, but for $12.00, it's kinda hard to pass up, especially when no one else seems to touch civil aviation. I'm building the Bonanza right now, so I'm right there cursin these kits with ya!!!!
Posted by Bones-coa on Friday, January 30, 2004 6:47 AM
Well, that's true. I only payed $15 for this kit.
I finished up filling and fixing seams on the fuselage last night. Tonight, it'll be the wings and those cowling gaps. YUK!!
