True Details Fast Frames question
Posted by tigerman on Thursday, September 22, 2011 11:21 PM
I scored one for my J2M6 Jack at the show last weekend, because it was very cheap.
So it appears you paint the frame itself, rather then cut out masks for the windows, though it looks as though that could be done. Are these better then Eduard EZ masks, which I have a set for another plane? Any tips? Thanks.
 Eric
Posted by MKelley on Friday, September 23, 2011 4:40 AM
EZ masks are better by far. I have tried them and they are terrible. 2 cents
Posted by echolmberg on Friday, September 23, 2011 8:30 AM
I tried those Fast Frames a few years back and really didn't care much for them.  They went on easily enough but once you have them placed exactly where you want them, you have to be verrrrrrry careful not to bump/nudge/touch them all all while the adhesive sets.  They slide around very easily which is great when you're trying to position them but lousy once you DO have it positioned exactly where you want it.
I think my biggest pet peeve was the fact that they didn't look all that good once all was said and done.  It kind of looks like someone painted carefully cut strips of Scotch tape and applied them to the canopy.  They covered any framing detail that was imparted on the clear plastic canopy.  They were flat and featureless.  Having never used them before, I thought maybe they would settle down and conform but such was not the case.  I wouldn't use them again.
Excellent in concept.  Lousy in actual application.  Go with the EZ Masks if you can.  Or better yet, save your money and use something like rubber cement or white glue to mask your canopy.
Eric
    August 2006
Posted by HawkeyeHobbies on Friday, September 23, 2011 9:00 AM
They are better for aircraft that have crude and distinctive frame work.
Paint them, let the paint cure then apply a sealer of some type before applying them to the canopy.
FF are an alternative to masking the canopy and paint the canopy itself. Again you have to look at your subject and see which offers the best appearance option after applied and finished.
Gerald "Hawkeye" Voigt
Posted by tigerman on Friday, September 23, 2011 9:57 AM
Thanks for the thoughts guys.
Eric, I kind of agree that would look a little like painted masking tape. I might reconsider this.
 Eric
Posted by Ashley on Friday, September 23, 2011 10:20 AM
You can get very good framing yourself with aluminum foil and Micro-Metal Foil Adhesive. Paint one side of a piece of foil with the interior frame color, the other with the exterior. The trick here is to prime the foil with self-etching primer, available at any auto parts store and many box home-improvement places. Then use a straightedge and a NEW blade to lightly score through the foil to cut out the width of framing you need, then coat the interior side with the adhesive, and apply it to the canopy. You can Future the canopy beforehand, and this will allow you to remove a piece if you don't like the position or appearance. Burnish the frame in place by rolling a Q-tip over it, you don't want to scrub the paint off the foil. With practice and patience, you can cut the strips to include the gussets and angles in the frames, or apply them separately as they were often riveted over top of the straight frames. You will have to use a brush to fix little glitches and to paint the edges of the canopy and windshields. The foil will conform to some pretty acute compound curves without wrinkles, you might have to cut some of the strips with a curve on some applications, I needed to cut circular frames when I did a 1/72 Betty. I pretty much do all my birdcage canopies this way now.
Have you flown a Ford lately?
Posted by tigerman on Friday, September 23, 2011 5:06 PM
Ashley
Boy Ashley, that seems advanced for a newb like me.
Was wondering about the FF: can you just cut the windows out and use them like the Eduard masks? They seem precut enough. In other words, throw out the frames?
 Eric
    July 2006
Posted by constructor on Friday, September 23, 2011 5:19 PM
Still nothing like masking thewindows.
    August 2009
Posted by TREYZX10R on Friday, September 23, 2011 5:49 PM
Eric I used the fast frames on my Zero in the Japanese G/B just because they came with the kit I won on ebay and wo'nt be using them again! Yes you could use the cut outs as a mask but I'll stick with masking my own from now on. The foil technique is nice but requires a fair amount of skill to pull off effectively ,Eduard masks are by far the best route and I always spray the interior color first then some silver so I can chip the top coat a bit,hope that helps,Trey
Posted by tigerman on Saturday, September 24, 2011 1:58 AM
TREYZX10R
Thanks Trey. How do you do your masking?
 Eric
    January 2014
Posted by Silver on Saturday, May 9, 2015 6:15 PM
Fast frames are good but you will have to follow the instructions and paint them.EZ mask came out later and it is another type of process.Fast frames I think are out of production.They both slide into position w/soapy water..
    January 2014
Posted by Silver on Monday, May 11, 2015 6:25 PM
I placed 1st many times at contest using both.
    January 2014
Posted by Silver on Tuesday, May 12, 2015 10:31 AM
Ex mask now is one of the best when it comes to an Me-110 in 1/49 scale or an avenger and so on.Do not leave EZ mask on for long periods because it will be hard to remove.Its best for same day application and use.
