If the kit comes with a pilot figure - and you're up for a little surgery - try positioning the pilot in some position other than looking dead ahead at the instrument panel.
I have gotten in the habit of chopping off heads, arms, legs, and torsos, and re-positioning them so that the pilot is climbing aboard, or exiting the cockpit, or doing something non-robotic.
I kindof finished an Airfix 1/24 Spit about a year ago. The pilot sits with the door open and the hood back, his torso is twisted slightly to his left, his head is turned so he's looking just forward of the port wing, left elbow outside the plane and his right arm waving. It's like he's just waving to a friend after returning from a sortie over the channel.
I haven't built the Revel kit so I don't know if it's wheel wells are boxed in, that is - do they have walls ? I had to make my own for the Airfix kit. A tip: If you have to box them in - use the thinnest plastic sheet you can get. I used stuff that was a little on the thick side and it was a real pain to get it to stay in place until everything was solid. It looks great though - definitely an improvement over the hollowness that would have been there if I had not done it.
