drilling small holes
Posted by Anonymous on Saturday, January 31, 2004 4:25 PM
Hey guys,
New to the forum and I have learned more from you guys than from several books I own. I have attempted with little success to drill out gun barrels and exhaust stacks in the 1/48th scale. I seem to break bits or have a hard time staying centered. I am using a pin vise. Any tricks you can suggest or perhaps a tool purchase to help? Also where I am from hypodermics are illegal without a prescription so that is out any sources out there to purchase from? I checked small parts.com but the web sight is not currently valid. Big Smile [:D]
Posted by Anonymous on Saturday, January 31, 2004 4:53 PM
Hi Falco. I'm no expert, but this may be of help to you. How about using plastic rod? There are some companies that make sheets, tubing, etc. of styrene plastic. I'm sure you could find some that would be good enough for 1/48 gun barrels. It is usually sold in packages that offer several lengthy pieces for a very reasonable (cheap) price. Use an appropriate sized bit, and practice, practice, practice. Pirate [oX)]
Posted by Anonymous on Saturday, January 31, 2004 5:04 PM
For 1/48 gun barrels, I use a new #11 Xacto blade. Under magnification, I push the blade in gently, then remove it. If its where I want it, I then re-insert it, and twirl it slowly, checking frequently for alignment & size. I use the same method for exhausts. Some oval ones require extra "shaving" on either side of the center hole.
Hope this helps.
    July 2003
Posted by nmayhew on Saturday, January 31, 2004 5:13 PM
Falco hi, and welcome!
Sign - Welcome [#welcome]
i use pixilater's method alot...it works!!Smile [:)] i have used micro-mini drill bits (down to 0.4mm) sometimes for 1/35 MG barrels but generally i get greater flexibility from the hand-held x-acto method.
i would suggest that if drill bits are breaking drilling into normal plastic, the bit you are using is too small and frail or the piece you are drilling is not being restrained properly.
regards,
nick
Kind regards, Nicholas
Posted by gregers on Saturday, January 31, 2004 5:56 PM
for small scale tubing try looking in the model railway ection of your LHS, they normaly have that sort of stuff in various sizes. i use it to make u/c legs in 1/72 for vacform kits.
Greg
Why torture yourself when life will do it for you?
Posted by Melgyver on Saturday, January 31, 2004 7:53 PM
A buddy of mine took small dowels about the size dia. of paint brushes and drilled one end with the drill bit then glued the drill bit into the dowel. He did that with his whole set of small bits and just used them to make small holes in gun barrels and hinges on his vehicles. They are easy to turn in your finges and adjust pressure. I did this with a couple small bits only used aluminum tubing instead.
Clear Left!
Mel
Posted by Anonymous on Saturday, January 31, 2004 9:16 PM
Us ship modelers know your dilema all to well, try drilling out all the 40mm on an Iowa Class BB and you see what I mean. Personally, I clamp my gun barrels in a small vise, with plenty of padding to protect it from the vise marks, and use my dremel drill press to drill the holes. With the press there is no danger of the bit "walking" around on you, and it stays centered. Just make sure the barrel is siting straight in the vise. Has worked very well for me and I drill out about 40 to 50 guns per model unlike you "flyboys" and your 1 or 2. LOL
Posted by Melgyver on Saturday, January 31, 2004 10:08 PM
Don't forget about exhaust stacks, drain holes and vents! Not as many holes as "boat people" but still more than a couple! Any way I thought you made the Marines do all the hard work! Just kidding guys!
Clear Left!
Mel
Posted by Anonymous on Saturday, January 31, 2004 10:13 PM
I use my lathe (turned by hand for plastic) because it keeps things restrained and centered. The Dremel drill press idea will do a good job of this as well. If you are breaking bits then either the part or the bit is wobbling off center.
If you don't have or cannot afford these tools then go with Pix's idea of using the #11 bit.
Good luck,
Bruce
    November 2003
Posted by orion32 on Sunday, February 1, 2004 8:21 AM
Falco,
As you can see there a a lot of ways to drill out gun barrels. I have a set of drill bits that range from.039 #61 to .0135 #80. I believe Walthers is the company that distibutes it. They even come in a little bit box. I first square off the end of the barrel with a sanding stick or small file. This gives me a straight edge and prevents the bit from slipping. Next, using a magnifying glass, I make a small indentation in the center of the barrel with a small pin. This gives my bit a place to start. I spin the pin vise between my fingers and thumb to make the hole. Remember! You do not have to go to very deep. Check your alignment to see if it is where it should be. That's why I said do not go deep. If it is off, sand the end smooth and try again. Once the hole is done, slightly round off the edge, apply some flat black in the hole and paint the barrel. Hope this helps.
Ed
ED
    December 2003
Posted by Quagmyre on Sunday, February 1, 2004 11:01 AM
[img=right]http://www.ryanahern.net/Files/Pics/P1310031.jpg[/img=right]
Every now and then I find some great subtitute parts in the jewelry making depts. of Hobby Lobby or Michaels. There you can find these small aluminum or brass tubes. See pic. These are great for replacement stacks, vents, etc., but may require a little straightening to work well. Isn't that always the case. These are also good for making antennae as well since the fishing line (or 0.5mm bead/jewelry cord) tugs a little to hard for the plastic antennae provided by the manufacturers.
Current and Subsequent Projects:
1/48 scale Tamiya P-47 "Razorback" - Complete
1/48 scale Testors/Lone Star Models PT-22 Recruit - 20% Complete
1/48 scale Monogram C-47 Skytrain - Not Started
