Canopy painting question
Posted by rcboater on Sunday, February 1, 2004 12:44 PM
I'm working on a Tamiya 1/72 scale Spitfire Mk1. On this kit, the canopy is 2 pieces- the windscreen is one piece, and the rest of the canopy is the other.
Now, if this was a typical 1/72 model with a one piece canopy, I would just mask and paint the unit as usual.
My question is, because the canopy is 2-piece, should I paint the edges of the canopy frames, before I install the pieces? I'm talking about the edges of the piece, parts that would certainly be painted if the canopy was posed in the open. But in this case, the canopy will be closed, so the two edges (rear edge of the windscreen and leading edge of the hood) will be glued together, as the canopy will be installed in the closed position.
It seems that I have two choices here:
1. Don't paint the edges, and hope that the paint on the exterior of the canopy, on the framing, will hide glue seam where the two pieces are joined.
2. Paint the edges, so there's no clear-on-clear glue joint, but highlighting the fact that the canopy is much thicker than scale.
I'm building this kit OOB, so a vac canopy is not an option. I'm starting with the fairly thick, but clear, kit canopy that has been dipped in Future, and I'll be using Testors clear parts cement on whatever I end up doing.....
TIA!
-Bill
Webmaster, Marine Modelers Club of New England
www.marinemodelers.org
    July 2003
Posted by nmayhew on Sunday, February 1, 2004 12:52 PM
hi there rcboater,Smile [:)]
braille scale isn't really my thing but i would guess that option 1 will be fine as i'm sure the paint on the exterior will hide the joint. i'm not familiar with the testors glue you mention (don't see much of their stuff over here), but if it's like the "mico kristal klear" that i use, you shouldn't have any problems.
i'm currently doing a battle of britain 1/48 spit by the way, with the day/night underside. what scheme will yours be?
best of luck.
regards,
nick
Kind regards, Nicholas
Posted by rcboater on Sunday, February 1, 2004 1:02 PM
I'm doing one of the two schemes the kit does- the one with all sky undersides, and no markings under the wings. (I chickened out on trying to mask the other option- all sky except for one wing in black.)
