OV-10 Bronco
OV-10 Bronco
Posted by Anonymous on Sunday, February 1, 2004 11:55 PM
Does any one know where i might find one of these in kit form???? Plastic or otherwise??
Thanks
Posted by Anonymous on Monday, February 2, 2004 12:00 AM
Hasegawa has/had one in 1/72, I think there was also a 1/48 version out (Monogramm?? Revell??)
Did about 3 of the hasegawa ones when I was still into plane models.
Posted by Butz on Monday, February 2, 2004 12:04 AM
Hey littlemoe,
You may want to check w/ Academy. I believe they did a Bronco in 1/72d scale. Also Testor did one in 48th. Not bad over all but the detail was lacking though.
DUHTongue [:P] Academy OV-10A kit # 1165. I also think they did or are coming out with the OV-10D
Hope this helps ya out a bit.
Flaps up, Mike
  If you would listen to everybody about the inaccuracies, most of the kits on your shelf would not have been built Too Close For Guns, Switching To Finger
Posted by Anonymous on Monday, February 2, 2004 12:05 AM
awesome!!!!
thanks guys!!!
Posted by Butz on Monday, February 2, 2004 12:07 AM
Yup haseagwa did one as well. Thanks MMF. Na only Testors did a Bronco in 48th that I know of.
If it was Revell or Monogram that put out one, I would have grabed a few for sure.
Flaps up, Mike
Posted by Anonymous on Monday, February 2, 2004 12:11 AM
the academy had a 0v-10d bronco in 1/72 scale. thay had a ov-10a bronco also available from academy.Smile [:)]
    November 2003
Posted by chopperfan on Monday, February 2, 2004 12:12 AM
Testors had one in 1/48. It was basic. Needs a lot of work to make it passable. There are resin and PE sets for it though.
Hasegawa has one in 1/72. Needs a little added work, also. They also released a version like the one in the top picture, an OV-10D, with a new nose piece cast in white metal.
There is another in 1/72, Academy I think, but I believe it is the Hasegawa kit reboxed.
Those are the only ones that I know of.
Good luck. You may still be able to find them.
Randie Cowboy [C):-)]
Randie [C):-)]Agape Models Without them? The men on the ground would have to work a lot harder. You can help. Please keep 'em flying! http://www.airtanker.com/
Posted by Anonymous on Monday, February 2, 2004 12:17 AM
thanks guys, i found two acadamey 1/72 kits... one from nam and the the other from desert storm... the D model
http://www.scalehobby.com/advanced_search_result.php?keywords=OV-10+Bronco&osCsid=d5167d10356e18522e9e68669841ff37
Posted by Anonymous on Monday, February 2, 2004 12:22 AM
kool i found the testors one.... how are the testors kits????
http://www.ehobbies.com/1001-6009.html
Posted by Anonymous on Monday, February 2, 2004 12:23 AM
where can i find the resin and PE kits for it???
    July 2003
Posted by oldhooker on Monday, February 2, 2004 8:17 AM
Hi Littlemore,
I found this fellow on E-Bay who offers several of the 1/72nd OV-10 kits with the PE set included, REALLY cheap! Here's the link to one of his auctions... once you're there, click on "View seller's other items", to see the other varieties he has.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=3173062784&category=50298
Hope this helps,
Frank
Posted by berny13 on Monday, February 2, 2004 9:17 AM
Stay away from the Testors kit in 1/48. I got one many years ago. My son worked on them at George AFB and I was going to build one for him. The kit is so bad I finally gave it away to my Granddaughter. That is a great way to recycle kit I no longer want. Go with the 1/72 scales if you can get them.
Berny
 Phormer Phantom Phixer
On the bench
Posted by Anonymous on Monday, February 2, 2004 1:01 PM
thanks for thatlink hooker, he's pretty cheap!!!
1/72is kinda small right??
Posted by Anonymous on Monday, February 2, 2004 3:32 PM
Ron, I've got the Academy OV-10D "Desert Storm" I'm planning on building it for the USMC group build, when I start it I'll let you know how it looks. In the box it looks great, crisp evgraved lines even, although it's in a lot of pieces.
    January 2003
Posted by stinger on Monday, February 2, 2004 4:25 PM
Flaps up, Mike
Hey Mike, were you referring to a Revell 1/48th, or 1/72nd?
Funny that this topic came up when it did, as I just bought an old 1/72nd Revell on eBay last night for five bucks. Is it a good kit?
LittleMoe - Before I searched eBay, I checked with www.greatmodels.com . They have a few listed as "in stock", and they are taking pre-orders on a new Hasa release, but I forget which type of -10 it is.
later,
stinger
May an Angel be your wingman, and the Sun be always at your six
    June 2003
Posted by garys on Monday, February 2, 2004 4:41 PM
The Revell 1/72 kit is a classic but until the Academy kit was released it could be considered the best. It still needs a lot of detail work though. The Hasegawa kit has some good points, mostly bad, and again the Academy is better. The Testors 1/48 is a rerelease of the old Hawk kit and was also released by Italeri, and as mentioned also needs work. Because it is the only 1/48 kit ity can be made into quite an eye catcher with the added work mentioned by others.
Posted by Butz on Monday, February 2, 2004 6:28 PM
Hey Stinger,
Sorry I did not explain fully DUHSad [:(]. What I was trying to say is if Monogram/Revell did a 48th OV-10, I would definetly pick a few up instead of the Testors kitDead [xx(].
Maybe Hasegawa or Tamiya will do one in the near future. Only time will tell..!! If the modeling Gods are listening, so what do ya say??
Flaps up, Mike
    April 2014
Posted by r13b20 on Tuesday, February 3, 2004 3:02 PM
Had one of those when I was a kid. Tail heavy!!!
    November 2003
Posted by tempestjohnny on Tuesday, February 3, 2004 3:41 PM
Littlemoe These kits are very tailheavy. There is not much room to pout weight in the nose. Also I don't think the landing gear would take the weight anyway. You are better off making a stand for the tail. JOHN
Posted by wayne baker on Thursday, February 5, 2004 11:41 AM
Dug out my Hawk kit last night. The cockpit resin kit is a Missing Links set. Didn't look to see if they are still in business, or who might have one left. When I get around to building it, looks like you can put shot in the wings and nacelles to make it sit on the nose gear.
 I may get so drunk, I have to crawl home. But dammit, I'll crawl like a Marine.
Posted by Anonymous on Friday, February 6, 2004 6:57 AM
Thanks alot fella's!!!!!! I thought for sure everyone was gunna say "OV what?????""
I didnt think this plane was popular!!!!!
Thanks again for all the help!!!!!!
