pzl66: Roger that. Following your instructions, I sprayed a rather heavy coat, close up, contary to the instructions on the can, which tell you to spray 2 or 3 very thin coats 15 seconds apart., from 6" to 8" away. That did not work, gave me the orange peel effect.
Then before I saw your last note, I made the mistake of touching it after a couple hours, and that really messed it up. A 48 hour wait is probably what I needed to do.
Conclusion- this stuff is too fussy for me. For a few bucks more, I think I will use Alclad II.
Thank you for your help!
Chuck
