In some a/c there is actually a wrapped tail effect to counteract engine torque and actually it does save you pedal effort. The angle is 3-5 degrees at the most.
So better check with scale plans first!!!! If the skyraider is zero degrees set then you can still force it into the correct angle even if it is glued together, by using warm water...
