Thank you so very much, garydmason, Frank, Rick, Jason, John, benzdoc, John, & Butz !
This really was a fun kit to build, except for the flaps.
Frank - the Ta 152 DOES kinda look like someone took a pic of a 190D with a wide angle lens !
Rick & Butz - the only real difficulty I've had with the basic kit is getting the accessories aligned at the back of the engine. Lots of dry fitting & trimming. The kit PE is stainless steel, which is thicker & stronger than "standard" (like Eduard) PE. Folding the hooks for the bottom portion of the sliding canopy without losing them is a challenge. Cleaning up the nav lights is also pretty tricky. The gun tubes are separate parts, so aligning them with the wing openings & attachment points at the back of the wheel well requires care. If you build it with the cowl panels open (how I'll build my next one), a LOT of care is required to keep everything true & aligned. References are pretty scarce on the net (one unrestored bird in existence - owned by the NASM) Overall, its one of Trimaster/DML/Dragon's best fitting kits.
Butz - I was unaware that Tamiya produced a Ta 152. When did they make that? Is it 1/48? I've still got a couple more DML kits to build. Just curious, as I haden't heard of it before.
I am very happy that all of you enjoyed looking at my Ta 152. Its a priviledge to share mywork with all you fine people !
Now...where did I put the Me 262?
