PBY-5A Wheel well colors?
    June 2003
Posted by Gundamhead on Saturday, February 7, 2004 8:38 PM
I've seen white struts with black wells. I've seen green struts with white wells. Anybody have some links to pictures?
Posted by Anonymous on Saturday, February 7, 2004 9:45 PM
Try the Detail & Scale Number 66 for the PBY. It has MANY up-close color detail shots of the wheel wells. White struts & wells, or Gray struts & wells will work as well as the colors that you mentioned above.
    December 2003
Posted by Quagmyre on Sunday, February 8, 2004 12:17 AM
http://www.pby.com
White was most common. Some wells were even left unpainted since the only time a PBY had its gear down for the most part was when it was being worked on or just plain out of service on land. White isn't exaclty the most effective camouflage on land, unless it's snowing I guess. Hmmm... some PBYs did fly in and out of Alaska.
Current and Subsequent Projects:
1/48 scale Tamiya P-47 "Razorback" - Complete
1/48 scale Testors/Lone Star Models PT-22 Recruit - 20% Complete
1/48 scale Monogram C-47 Skytrain - Not Started
    May 2003
Posted by qmiester on Sunday, February 8, 2004 8:09 AM
Most of the shots of -5As in Squadrons PBY in Action show the wheel wells painted in black.
Quagmyre,
Remember that for the most of the last half of the war the US Navy and the RAF operating patrol bombers against subs in the Atlantic and Med that were painted white and grey. They weren't worried about the a/c being seen on the ramp but were trying to make it less visible at a distance when flying over the sea. Same reason that military today paints their aircraft in greys.
Quincy
    January 2003
  • From: Upper left side of the lower Penninsula of Mich
Posted by dkmacin on Sunday, February 8, 2004 8:58 AM
It has taken almost this long to show the "brass" that white is an effective color for wheel wells, why? Easier to find a leak and trace the source. Red means hydralic fluid, the most prevelant fluid in a wheel well, but it could have lubrication, coolant, water lines as well. against black or a darl color it would be very hard to find a leaks source.
And a pilot might just write up, "fluid leaking in right well." Not too helpful. Like the pilot that wrote up, "Fluid leaking from aft of aircraft on ground." for me back in 1979. . .it was the relief tube being used!!
Don
I know it's only rock and roll, but I like it.
    June 2003
Posted by Gundamhead on Sunday, February 8, 2004 11:44 AM
Thanks for the help guys. I know these got slapped with paint all the time to fight corrosion. Anybody know the factory fresh colors for a blue-grey cat? Blue wells with black struts? Green wells with black struts?
