zinc chromate on ww2 aircraft
    April 2006
Posted by jgeratic on Saturday, May 26, 2012 12:45 PM
I'm aware this colour was used in cockpits and wheel wells, but was it also used as a primer overall or on the outside  wing surfaces?
regards,
Jack
    September 2009
Posted by satch_ip on Saturday, May 26, 2012 1:02 PM
It was used on the internal structural parts.  The stringers, longerons, and ribs.  The exterior was sheet aluminum or duraluminum.  P-51 wings were covered in a aluminum lacquer.
    January 2012
Posted by Cdn Colin on Saturday, May 26, 2012 1:06 PM
I'm pretty sure they did use it as a primer before putting OD and grey down.  I've seen a picture of B-25's on the assembly line like this.  They stopped priming the outside when they went to bare aluminum.
I build 1/48 scale WW2 fighters.
Have fun.
    April 2006
Posted by jgeratic on Saturday, May 26, 2012 1:16 PM
Ok so that's a no and a yes? lol
I did read somewhere an aircraft primed overall in zinc chromate would have added significant weight, plus the cost factor.
It's just lately I've seen some Hellcat builds and the wing chipping has this colour and was wondering of it's correctness.
regards,
Jack
    September 2003
Posted by checkmateking02 on Saturday, May 26, 2012 2:15 PM
    October 2005
Posted by antoni on Sunday, May 27, 2012 4:58 AM
Zinc chromate is a bright yellow pigment with corrosion inhibiting properties. Because the bright yellow colour was believed to cause eye strain it was forbidden to use yellow zinc chromate in crew areas. Instead a green version, made by adding carbon black pigment, was substituted in these areas.
Pure aluminium is resistant corrosion as a thin film of aluminium oxide forms on the surface protecting the metal from further oxidation. However aluminium is also rather soft and not that strong limiting its use in aircraft construction. Therefore alloys such as duralumin were developed. Alclad is a sheet of duralumin sandwiched between two very thin sheets of aluminium which gives it corrosion resistance. It goes without saying that it would not normally require corrosion inhibiting primers.
Primers, both pigmented and unpigmented, may be required for other purposes. Unpigmented primers (clear lacquers) are usually used to obtain better adhesion for the first coat of paint. Mr Hobby’s Mr. Metal Primer is an example of one such clear lacquer primer. There are also filler primers, sometimes called levelling primers or sanding primers, which are used to produce a very smooth and even surface for paint, filling in small scratches and imperfections. They usually require sanding and are often a yellow or red colour rather than the usual grey.
In the case of the P-51 Mustang the fuselage was given a light coat of primer.
The first 40% of the wing chord was sprayed with one coat of zinc chromate primer followed by enough coats of Acme Gray Surfacer No. 53N5 to cover all irregularities. Skin butt joints were then filled with Acme Red Vellunite glazing putty N 58485. The entire area was then sanded and sprayed with one coat of camouflage enamel. When camouflage was deleted, the forward portion of the wing (sometimes the entire wing) was sprayed aluminium. The lower photograph shows how the interior of the wing was or was not finished.
On 1st January 1944, NAA issued a factory order regarding the deletion of camouflage paint from future fighter and bomber aircraft production. It stated: “At the earliest date, without delaying production, camouflage paint will be deleted from all spares delivered concurrently with airplanes without camouflage. Exterior surfaces such as fabric, plywood, magnesium, and dural will require protective primers of aluminiumized coloring. Alclad or stainless steel will require no covering. Antiglare paint will be on top of the fuselage covering forward vision areas to aid the pilot. The propellers will remain black with yellow tips.”
“The wing leading edge of the Mustang will be smoothed and surfaced as outlined in the P-51B and P51C Series Repair Manual Repoert no NA-5741, with the exception of that the camouflage coats will be deleted and aluminiumized lacquer will be applied over the surfaces. The deletion of the camouflage will eliminate approximately 42 pounds of finish from the B-25 Series Airplanes and 16 pounds of finish from the P-51 Series Airplanes. It is anticipated that the removal of the camouflage will also result in materially increased speed.”
Camouflage at the factory was removed with a type of thinner that did not attack the gray airfoil smoother. However, thinners available in the field would damage and remove this important coating. Rivet heads, rough edges etc would be exposed and cause extra drag. To prevent this NNA recommended that USAAF bases use the following procedure:
“In place of removing the camouflage from the airfoil smoother, apply addional paint to the area, which extends from the wing leading edge to approximately 40 percent wing chord. Use a mixture containing 8 ounces of aluminium paste to each unthinned gallon of clear lacquer (Spec. AN-TT-L-51) or clear varnish (Spec. AN-TT-V-118). This will allow the surface to assume the necessary appearance of unpainted aluminium or stainless steel. Any specified thinner may be used for the removal of camouflage from all other surfaces of the aircraft.”
    June 2008
Posted by Hans von Hammer on Sunday, May 27, 2012 2:56 PM
And then ground crews quickly read the order and then cheerfully headed to the line shack's paint-locker and pulled out the rags and the five-gallon cans to be filled with 100-Octane AvGas...
    July 2004
Posted by stikpusher on Sunday, May 27, 2012 3:45 PM
jgeratic1
I would not go with that as a reference. Aside from all the information posted here already, look for period color photos. Yes US aircraft were primed in the factory before camoflage painting, but most photos will show that where the topside paint is worn away, the primer beneath usually is as well, exposing the metal beneath.
This is probably something like the extensive tank chipping that is seen so prevelent on armor builds currently, but rarely seen in reality.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    January 2009
Posted by fermis on Sunday, May 27, 2012 4:45 PM
Here's a couple shots from "War In The Pacific" (full of excellent color photos!)
First is the Corsair....looks like a more green chromate on the wings.
...and here's a Hellcat.....looks like yellow zinc to me! (could be smoke and mirrors thoughMovie)
Posted by Anonymous on Sunday, May 27, 2012 5:59 PM
stikpusher
 jgeratic1:
I agree.  And while we are on the subject, the term of "paint-chipping" to me is a very poor description of paint that is actually being "scuffed" or "abraided" down by constant foot traffic or some other abrassive force (similar to what sand-paper would do)...the paint is not actually peeling or being "chipped" off...
    January 2009
Posted by fermis on Sunday, May 27, 2012 6:14 PM
Manstein's revenge
......unless it's Japanese!
    July 2004
Posted by stikpusher on Sunday, May 27, 2012 10:36 PM
jgeratic1
regards,
Jack
Well on the B-25 I would say yes
       - Plankton
LSM
Posted by Anonymous on Monday, May 28, 2012 8:17 AM
fermis
 Manstein's revenge:
http://upload.wikimedia.org/wikipedia/commons/6/69/Ki-43s_and_Ki-84s.jpg
Good point---and GREAT pic!  The Japanese paint did tend to flake off during flight from the flexing of the airframe and from engine vibrations...
    June 2008
Posted by Hans von Hammer on Monday, May 28, 2012 11:05 AM
fermis
 Manstein's revenge:
Or a P-61...
Northrop had big QC issues with the Gloss Black paint they used... It wasn't unusual to see Widows with 40-50% of the black paint chipped-off..
I think a major portion of it was due to paint being applied un-primed, hastily-cleaned surfaces, Manny..
    May 2012
Posted by Old Ordie on Monday, May 28, 2012 12:37 PM
Manstein's revenge
Good point.  Paint does chip off as well, but that is mostly due to impacts with material in the air (or on the ground... as in "Oops, sorry chief").  I'm an annual member of the Tri-State Warbird Museum, and the restored WWII planes there are all fairly regularly flown.  The SNJ recently hit something that left a fist-size dent in the leading edge of the port wing and chipped the paint clean off the spot and maybe an average of an inch or so around it, clear down to bare metal.  Mostly, though, paint disappears on aircraft through wear, as you describe.
I know I'm an FNG around here, but, while we're on the subject - though the model-building skill I see evidenced on the 'net is absolutely spectacular, on this site and elsewhere - this whole paint-chipping thing seems to me to be a bit overdone.  OK, a Marine or USAAC taking off from a coral atoll every day during sustained combat operations might get chipped to hell, and to tell that story a modeller should chip the plane up real good, but on most planes just a little actual chipping does it (leading edges of props, wings, tail, and access panels, etc. ...).  Paint wear is a different matter.
This is even more true of Navy planes.  While you probably can't make a carrier plane dirty enough (or, especially in WWII, faded enough or dinged-up enough), there would be very little chipping on the exterior surfaces.  Bare metal and salt spray don't get along well at all, and the squadron/group/ship corrosion control officers are diligent guys.  The Navy habitually paints everything, that can be painted under prevailing circumstances, all the time.  While there is always foot/shoulder/leg/hand worn bare metal in the cockpit and equipment bays, there is never much to be seen on the exteriors of Navy planes, even under combat conditions.  I have seen a (very) few pictures of chipped up WWII US carrier planes, and those were of planes that had been in daily combat for extended periods, and even they were not chipped that much, generally.  My own experience in the Gulf of Tonkin runs even with what I am saying.
Back on topic, zinc-chromate can be found on all other-wise unpainted interior aircraft surfaces.  I have read that, in WWII, it was not uncommon to find three different shades of the stuff (one yellow, two green) inside different parts of of the same plane coming out of the factory.  But I don't believe otherwise painted surfaces generally are primed with it.  EDIT:  But, looking at some of the above photos, especially those B-25s, I could be wrong ...
Flight deck:  Hasegawa 1:48 P-40E; Tamiya 1:48 A6M2 N Type 2 ('Rufe')
Elevators:  Airfix 1:72 Grumman Duck; AM 1:72 F-4J
    June 2008
Posted by Hans von Hammer on Monday, May 28, 2012 1:11 PM
Don't go into what really  happens to aircraft due to weather and operational conditions here, Ordie..
We're talikng about authenticity and realism here... Wink
    May 2012
Posted by Old Ordie on Monday, May 28, 2012 1:18 PM
Hans von Hammer
Oops ... sorry, chief. Geeked
    January 2009
Posted by F-8fanatic on Monday, May 28, 2012 4:44 PM
Something else to consider.....
Different components that were to go into different aircraft were produced by different factories.  It is very common to have more than one or two different shades of green zinc chromate on those parts in the same airplane.  Warbird Digest #13, from 2007, showed this perfectly...someone was restoring a T-6 Texan to as close to factory as possible, and in the process, they came across a lot of NOS original parts.  These parts, such as map cases, etc etc, were all different shades.
Also, make sure that you research the particular aircraft you are building.  The P-51, for example, had wooden floorboards, and these were not primed with zinc chromate.
Posted by Anonymous on Tuesday, May 29, 2012 8:26 AM
Old Ordie
 Manstein's revenge:
...yes...
    April 2006
Posted by jgeratic on Tuesday, May 29, 2012 12:40 PM
Thanks everyone for the responses.  I've been finding evidence, photo wise, on the exterior use what appears to be zinc chromate.  These are from a Corsair:
Linked from a photo set here: http://zone-five.net/showthread.php?t=15310
Here are the two built models of Hellcats I saw (along with links to their respective threads) that made me curious as to the use of zinc chromate on exteriors.  They are stunning works.  Some might consider the second one to be overly realistic, but is undoubtedly a virtual feast for the eyes (and that much more amazing at 1/72 scale!).
http://www.britmodeller.com/forums/index.php?showtopic=234919249
http://www.britmodeller.com/forums/index.php?showtopic=234918173
regards,
Jack
    May 2012
Posted by Old Ordie on Tuesday, May 29, 2012 7:59 PM
re: Corsair photos
Jack,
Sure looks like zinc-chromate under the exterior paint to me ... I would have bet against it.
    May 2012
Posted by Old Ordie on Wednesday, May 30, 2012 9:06 PM
Went down to the Tri-State Warbird Museum (Batavia, Ohio) today and took some photos of the Corsair they are rebuilding.  A lot of this bird has been "remanufactured" in the shop there, but, on the part that is still untouched, I couldn't see any zinc-chromate on any exterior surface where the paint was missing.  I didn't get to talk to any of the airframes guys as I'd hoped, as they were working (and getting paid, four of them - sweet job).  They rebuild by the book, using original drawings and specs.  I don't know what to infer from the way the "new" parts look right now, but there is very little zinc-chromate on the exterior surfaces of those, either.
You have brought up an interesting question here, and I'd hoped to get some skinny on it from the guys in the shop, but, like said, they were busy.  I have pretty much the run of the place, but not the shop, so talking to the restorers is pretty much hit and miss, and it didn't happen today.  I believe there may not be just one answer.  It could be one of those time-place-circumstance things.
Here's a closeup look at the remaining original section of the plane, paint missing areas (the green bit on the right of the first shot is tape), 2 views, followed by some shots of the rebuilt parts of the Corsair.  It was left abandoned on a bone-heap for the past 30 years or so, degrading away.  It is currently about two years from flying, but it will fly.
 What the hell, here's the engine, too:
And a re-built motor mount to go with it:
The engine will take a year and a large sum of money to rebuild, once it starts, and the wing-root/cockpit section remains unrestored because of all the electrical re-wiring it requires, but it'll get there.  The Museum is currently rebuilding a P-40 from New Zealand, and an Fw-190 as well.  They have a B-25, P-51, TBF (or M - it escapes me right now - EDIT:  It's a TBM-3, I have these "senior moments" from time to time ... end EDIT), a Stearman Kaydet and an SNJ, all of which fly.  But those are different stories ...
Posted by wdolson2 on Monday, June 4, 2012 5:29 AM
I worked for Boeing (commercial side) for a few years and had the opportunity to walk around the production floor a few times.
The airliners going down the production line have a zinc chromate sort of coating on the outer skin panels.  However when that plane goes into the paint hanger, the chromate coating is stripped off before the plane is painted.  The primer they use is a sort of neutral gray.
This is contemporary construction methods, but I think the practice was probably similar in WW II.  There may have been some factories or some cases where the outer chromate was not stripped before the final paint was applied and some factory photos show planes coming down the production line with all planes in bare metal, even ones that were painted.
Those pictures of planes that were showing zinc chromate green showing through where paint had warned may have been repainted at a depot where somebody decided to primer all planes getting repainted with zinc chromate before putting on the final paint.
There have been a lot of "what color interior" threads here.  The answer is that what standards there were often weren't followed very closely either in the factory or in the field so planes ended up with a wide variety of different painting techniques and patterns.
Bill
