While flying Fokker D.VII types, Jasta 46 was commanded by Ltn Otto Creutzmann (8 victories) as a part of Jagdgruppe 2. The pilot of this aircraft is unknown but it was photographed in British hands post war. The lower wing crosses should be further out by one half of a rib space. There is evidence that The unit may have had red or black forward fuselages. The top wing is in 5 colour lozenge while the bottom wing is in four colour. When you work with models like this and you follow the directions without some other references you can get in trouble. Eduard recommends the early fuselage for the following scheme. But here is what you need to know about the problems you will face. Remember folks you saw it here first. Eduard implied in their artwork, but they did not include it in their instructions. To do this scheme / profile as photo-evidence provides:
A. Instead of using the early production fuselage you could use the late production and cut off select louvres and add the photoetch metal louvres to match the profile. ( Also don't forget That even though Eduard shows the capped exhaust port - in the known images you can not see this. A new side panel may have been fabricated in the field) or...
B. If you use the early production fuselage you have to cap off the the side exhaust exit and carve out the rim on the upper cowling to allow for the high exit exhaust . Then add the Eduard photoetch louvres.
Anthology 2 has some very interesting images of this bird in British captivity (with 84 RAF 1918 -1919.) The altered side panels are a strong indication that this early Albatros built Fokker D.VII had not only both of the side and one upper panel altered BUT had its exhaust changed out from the "early side exit " type to the "later high exit" type. There is not enough evidence to prove that the engine was changed out and exhausts were a fairly common item. The engine we do see present is a Mercedes 180hp D.IIIaü type.
http://www.aeroscale.co.uk/modules.php?op=modload&name=Sections&file=index&req=viewarticle&artid=1149]
