I'm building Dragons P-38M (night Fighter variant)!
It has engraved detail and all the seam lines fall on panel lines....good detail and it will be a good kit!
Drawbacks
The canopy is a bit thick, but coat in Future and it gives the illusion of thin!
This kit needs a lot of filler and TLC...I haven't had to fill like this in a long time. EVen though the seams are on panel lines the fit is just downright nasty
FILL FILL FILL (some gaps are up to 1 mm (I'm canadian))
Dry fit a lot and make sure the booms and tailpiece are aligned....and don't forget weight in the nose!
Good luck
James
