decals that don't fit
    May 2003
Posted by nsclcctl on Monday, February 23, 2004 7:43 AM
I realize we should always dryfit parts and so forth, but how do you insure decals are going to fit before you get them off the backing? Case in point, I just finished the F86 Hasegawa Mig buster. Build went OK, not the best I have done but OK. I was working on decals when the yellow black checker pattern for the tail and the yellow black stripes on the wing tips simply were too big. They overlapped the other side. Unfortunately, they would not stick down over the edges for some reason. I am now faced with decals which when you look up close, clearly are too big. I am frustrated. Bottom line is, how do you dryfit these things so you can trim when necessary. Usually only happens with tail insignia and stripes on fuselage or wings.
Posted by rjkplasticmod on Monday, February 23, 2004 10:44 AM
You could measure their position on the model by using thin strips of masking tape where the decal edges should go, mark the end points, then remove and measure the tape. This will account for any curvature that the decal must cover. Then trim your decal to those dimensions. Or you could do what I do and that is to carefully trim the decal on the model. Use a very sharp Xacto knife and a straight edge. Don't try it while the decal is wet but don't wait too long for it to really adhere. Once sliced, you can remove the unwanted portion of the decal with a piece of Scotch tape. This is a little risky as you can damage the paint finish if you get careless, but with a little practice it's really quite easy to do.
Posted by Anonymous on Monday, February 23, 2004 11:01 AM
If there is a decal that appears questionable, you can scan it, print it, cut it out, then try it on the model. If its something that cannot be trimmed, or is too small, you can use the printed version to help create masks so you can paint it instead.
    January 2003
Posted by Jeff Herne on Monday, February 23, 2004 2:42 PM
In most cases, the decals are too big for a reason...in the case of hte F-86, since the checkers wrapped around the tail, they're meant to meet in the middle.
The best advice is to apply the decal to one side, overlap and all, and then use Micro-Sol to soften the decal so that it drops down onto the other side. Once that's done, allow it dry, trim with an X-acto knife blade, and repeat the process on the other side. You can then touch up any bad spots with paint, or, in the case of leading edges, weather accordingly. Painted surfaces did not last long on the leading edges of the control surfaces of high speed aircraft.
Jeff
    July 2003
Posted by nmayhew on Monday, February 23, 2004 3:26 PM
nsclcctl sorry to hear of your problemsDisapprove [V], but i agree with jeff re the micro sol solution...i've been really surprised in the past how a little perseverance and patience with micro sol can turn poorly fitting decals into the desired article.
good luckSmile [:)]
nick
Kind regards, Nicholas
