And now, for something completely different...
Posted by Anonymous on Wednesday, February 25, 2004 8:58 AM
...well, for me at least. This is an Olimp Models 1/72 Curtiss JN-4D "Jenny." I'm building the kit out of the box for a review, so I thought I'd share an in-progress shot with you. I haven't built a biplane for about 35 years, so its a nice diversion and challenge (all that rigging !) for me. Its a nice little kit, and I'll post pics of the finished product after I've submitted the review. If anyone can help me with tips for attaching the upper wing, I'd really appreciate it. I have plans that I scaled to the model, so I can make a jig for it. I just need to figure out where the jig can go to support & align the wings. Thanks in advance !
Posted by Anonymous on Wednesday, February 25, 2004 9:13 AM
It may be a completely different type of aircraft for you but I'm sure the quality of the finished product will be the same... awesome.
    September 2011
Posted by fightnjoe on Wednesday, February 25, 2004 9:53 AM
completely different but the same quality. you are a true artist pix.
joe
Veterans,
Thank You For Your Sacrifices,
Never To Be Forgotten
Where you can find me:
Workbench on FaceBook  Google Plus  YouTube
Posted by cassibill on Wednesday, February 25, 2004 10:19 AM
Differant in subject, same in skill. Thanks for the peek pix.
cdw My life flashes before my eyes and it mostly my life flashing before my eyes!!!Big Smile The 1/144 scale census and message board: http://144scalelist.freewebpage.org/index.html
Posted by rjkplasticmod on Wednesday, February 25, 2004 11:13 AM
Looking good Pix. Looking forward to seeing the finished model. Can't help you on the jig for the wing. I build a Bipe now and then, but just attach the upper wing with eyeball and prayer. There have been articles in a few of the mags over the years on making a jig, but reference escapes me.
Posted by Anonymous on Wednesday, February 25, 2004 12:22 PM
Thanks, AJACKETSFAN, fightinjoe, cassibill, & Rick !
The attachment pins, holes, & struts are small. I'm going to try & attach the struts to the bottom wing only, using the top wing for alignment. Once these are dry, I'm going to rig it, then attach the top wing. I'm hoping that someone here has had experience using a jig in this small scale. I have three more weeks to finish it, so I'm already planning on a few errors at this step.
Thanks again !
Posted by Woody on Wednesday, February 25, 2004 12:28 PM
Looks good so far Pix! I will be looking forward to seeing the finished plane. I remember reading on this forum a while back about using combs as an alignment jig.
" I wish to have no connection with any ship that does not sail fast; for I intend to go in harm's way." --John Paul Jones
    December 2003
Posted by snakedriver on Wednesday, February 25, 2004 12:36 PM
Pix,
I finished my first biplane a while ago (Dragon 1/48 Fokker DR1). I had good luck using styrofoam packing slabs to build a jig. I cut a base and attached the vertical pieces using a Scotch glue stick. Lay your model components across the vertical members and mark the width of the piece to be supported. Cut the foam slightly smaller than your piece. The foam has enough "give" to hold your piece securely, but not damage paint. The whole thing can be rotated, picked up, and moved. The glue sticks provide a strong enough bond to hold the jig components, but if you are nervous (Like I am) use some insect pins or shirt pins (I always save the ones from a new shirt) to reinforce your attachment points.
Another advantage of the styrofoam jig is you can add to the jig as you go. In the case of your Jenny, the lower wing and fuselage would be locked in. You can add verticals over your lower wing, adjusting the height and angle with a couple of dry fit struts. Once it looks right mark the spots for the upper wing and cut the mounting locations. Foam has enough "give so you can slip struts in and adjust length and angle before gluing without screwing the whole thing up.
Don't mean nothin'
Posted by Woody on Wednesday, February 25, 2004 12:38 PM
Here is the post Pix. http://www.finescale.com/fsm/community/forum/topic.asp?TOPIC_ID=3319 I hope this helps.
Posted by chasblake99 on Wednesday, February 25, 2004 1:59 PM
Pix
I've built a few Bi-planes and by inverting the aircraft and the upper wing, it was easier to support the fuselage at the correct attitude, install the braces, and get a straight assembly. You can use a pin through the propeller hub and support the elevator/horizontal stablizer at the same time.
Charles  NKAWTG (My KC-135R at RAF Fairfird during Allied Force) Pilots without crew chiefs are nothing but pedestrians with nice sunglasses and a cool jacket. Crew Chiefs RULE!
Posted by Lufbery on Wednesday, February 25, 2004 2:17 PM
Hey Woody,
I was just thinking about that jig. Big Smile [:D] Thanks for posting the link.
Pix,
Please keep us updated. For some strange reason, I love the Jenny. I'm planning on picking up one of the Olimp kits as soon as my current stash diminishes somewhat.
Regards,
-Drew
Build what you like; like what you build.
Posted by Anonymous on Wednesday, February 25, 2004 2:40 PM
Ah yes, Monty Python have at it! Lookinn' good.
Richard
Posted by Anonymous on Wednesday, February 25, 2004 3:28 PM
Looks good can't wait to see final picsThumbs Up [tup]
Posted by Anonymous on Wednesday, February 25, 2004 5:44 PM
Thanks, Woody, snakedriver, chasblake99, Lufbery, RSaddlemire, & BSquires, for your comments and suggestions. I feel less daunted by the prospect of getting this wing attached and aligned. I'll let you know how it goes.
Lufbery - the kit is nicely molded, with the struts and control horns in scale size & thickness. It matches a three-view profile I found on the web "to a T."
RSaddlemire - if this had been a tripe, I could have finished my intro with ...a plane with three wings!
Thanks again, everyone !
Posted by Anonymous on Thursday, February 26, 2004 12:51 AM
Lovin it!!! You're braver than I am, my friend!!
    November 2003
Posted by shrikes on Thursday, February 26, 2004 2:45 AM
Ah, the jenny! Beauty of an airplane (or would the more appropreate term be "flying machine")! I was about to suggest the Comb wing jig too, but Woody and Drew beat me to it! Tongue [:P]
Keep us updated, and how about a shot of the cockpit/engine area?
Blackadder: This plan's as cunning as a fox that used to be Professor of cunning at Oxford University but has now moved on and is working with the U.N at the high commission of cunning planning
    January 2003
Posted by stinger on Thursday, February 26, 2004 7:22 AM
Pix
Looking forward to the finished project.
I'd like to see some shots of the cockpit and engines, too.
I started an Eduard Pro-Fi kit of a DH-2 last fall. Man, those things are tiny. i admire your precision with such a small scale, but then, what else would we expect?
Keep us updated
Stinger
May an Angel be your wingman, and the Sun be always at your six
Posted by Lufbery on Thursday, February 26, 2004 8:25 AM
For what it's worth, here's a link to a page describing a rigging method that's very popular with WWI kit builders:
http://priswell.com/uggie/Uggie2.htm
Regards,
-Drew
    July 2003
Posted by oldhooker on Thursday, February 26, 2004 8:52 AM
Hi Pix,
I've never worked a 1/72 Jenny, but I attempted what you described about attaching the wing struts on the lower wing on a 1/48 version using the upper wing as a guide, removed the upper wing, rigged it using 1lb test Fly Fishing line, then attach the upper wing, but in my case, it was the process of tightening the rigging that misaligned the strut tops with the holes on the bottom of the upper wing.
I resolved it by removing the fishing line, attaching the upper wing, placed two foam blocks off each wingtip and pressing them slightly into the foam. Then I used stretched spru sections installed with needle nose tweezers and tightened using the blown match technique, but that wouldn't work on a 1/72, I don't think, without getting into some of the other rigging. Hmmmm.... you have raised an interesting question, and will follow this thread to see possible solutions.
Thanks... and BEAUTIFUL build!! (as is normal with you) Smile [:)]
Take care,
Frank
Posted by Anonymous on Thursday, February 26, 2004 9:50 AM
Thanks, kik36, shrikes, stinger, Lufbery, & Frank !
Thanks for the rigging link, Lufbery, and thanks for the rigging tip, Frank !
The plastic is soft, so I'm going to have to figure a way to keep the struts straight while I tighten the rigging.
Here's the cockpit & engine, shrikes. I still have to do a lot of work on the engine. I painted it steel, then gave it a coat of Future & a wash. I'll be going over parts of it with different metallics to get rid of the oversized-appearing "flakes." The plastic is white, so I didn't notice the seam lines 'till I painted it. They will be cleaned up later. The instruments are (out-of-register) decals. Its very accurate, compared to pics I found on the web, only missing some sidewall detail. But , since this build is for a review, I don't want to add anything that didn't come in the box.
Thanks again, for your comments, links, & suggestions ! I really appreciate it !
    September 2011
Posted by fightnjoe on Thursday, February 26, 2004 10:34 AM
awesome. is the engine just a two piece or is it more detailed than that?
joe
Veterans,
    July 2003
Posted by nmayhew on Thursday, February 26, 2004 11:07 AM
pix as ever great work...my only wonder is how do you work with stuff so small?![:0]Tongue [:P]
regards,
nick
Kind regards, Nicholas
Posted by Anonymous on Thursday, February 26, 2004 2:20 PM
Thanks, fightinjoe & Nick !
Magnification is the key, for me. I have to hold the model at arm's length just to get it in focus ! One of the "pleasurable little surprises" of getting older. Plus, my old builds don't look half-bad without my reading glasses !Laugh [(-D]
Posted by Anonymous on Thursday, February 26, 2004 2:31 PM
SWEET!!!!! You make models look good. Good job!
Posted by gregers on Thursday, February 26, 2004 2:54 PM
Hey Pix, exellent work man, i wish my builds were half as good as yours. i built a 1/48th jenny years ago an finished it as the one from the waldo peper film. i made wing jigs from plastic card and mounted the aircraft in a diving position so that both leading edges were at the same distance from the work bench. the wing struts i made from streched sprue filed to an aerofoil shape before stretching then shaped at the ends. i think the kit was by SMER but i ain't too sure on that.
thanks for sharing.
Greg
Why torture yourself when life will do it for you?
Posted by Anonymous on Thursday, February 26, 2004 10:03 PM
Thanks, J-Man & gregers ! I kinda wish this kit was 1/48...it would be a lot easier to finish. But, you work with what you got, right? Thanks again !
Posted by djmodels1999 on Friday, February 27, 2004 5:35 AM
Looks really nice, Pix. Nice to see some struts and strings in here!
Posted by J-Hulk on Friday, February 27, 2004 6:49 AM
Looking good, Pix!
Keep us posted on the progress!
~Brian
Posted by Lufbery on Friday, February 27, 2004 8:38 AM
Hey Pix,
This is going to sound odd, but I think the fact that the instrument panel decals are off register actually makes them look somewhat 3D. At least in your photo. Smile [:)]
Serendipity at work.
Regards,
-Drew
Posted by Anonymous on Friday, February 27, 2004 12:39 PM
Thanks, dj, Brian, & Lufbery ! The instruments may look a little 3-D from this side, but they sure look out of register from the other side! The panel is just a flat slab, so I can't add a drop of Future over the instruments Censored [censored] !
