- Member since
Ah yes, one of lifes' mysteries, the actual color of the prototype Spit. Much debate and some controversy over this topic. I don't know that anyone knows for sure, but here's what I learned when I researched a build a while back. The original paint scheme was overall a light blue/gray, but not as dark or vivid as Azure. Think RLM65 with some very light gray mixed in until it looks slightly more gray than blue. The forward portion of the spinner was in the overall color, but the rear portion was a dark reddish brown. The 2 bladed prop was baremetal, but had a dark grey (or black?) sheath fitted to the leading edges. The Roundels were standard white/blue/red center, but the fuselage Roundels appear to have a white surround. Serial # was K5054, in black with a white outline and appeared on the rear fuselage and rudder. After a forced landing and some airframe damage, the aircraft was repaired and repainted. This time, the undersides were silver and the upper surfaces in standard disruptive camo of dark green and dark earth. The serials remained in the same position but were in black without the white outline. Also all of the Roudels on the camouflaged surfaces were given a broad yellow surround. I am sure others may have different info, but like I said, the experts have debated this one for a long time. Hope this helps and good luck on your conversion.
RICK
At My Age, I've Seen It All, Done It All, But I Don't Remember It All...
