B 17 Serial Numbers
    October 2009
B 17 Serial Numbers
Posted by greentracker98 on Thursday, April 24, 2014 3:32 PM
Hi every one, I am going to be starting a B 17 in a couple of weeks. I'll be posting it to this thread.
Right now, I have a question. were/are the serial numbers painted on the tail? Also, would it be hard to cut off the chin turret to make it an E model. I know the cutting off part is easy. But, it's the part of finishing the chin to make it look right that I have questions and am leary about.
this link goes to Pacific Wrecks. It is a photo of the B17 my uncle was in when he disappeared after being attacked by a group of Zero's and shot down. There was only one surviver
My Uncle was Sgt Robert V. Copley. BTW
http://www.pacificwrecks.com/aircraft/b-17/41-2435.html
Thank You All
Ken Copley
A.K.A. Ken                Making Modeling Great Again
    November 2003
Posted by mississippivol on Thursday, April 24, 2014 5:16 PM
It should've been painted in yellow on the tail. You can find pictures that'll detail the placement. It might be easier to convert an "F" to the "E". You would need a new nose transparency, and the propellers are slimmer than the "F" and "G" models (someone, I think it was Bigfoot1, used C-47 props for that). If you're building in 1/48, some folks pick up Revell's "F" model and swap noses with the Monogram "G". Seems easier than having to scratch the nose piece.
    June 2013
Posted by RobGroot4 on Thursday, April 24, 2014 6:53 PM
Squadron sells aftermarket canopies for B-17g models.  Though as inexpensive as the Revell G is, it might be cheaper just to buy the G vice the squadron canopies.
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
    October 2009
Posted by greentracker98 on Thursday, April 24, 2014 6:56 PM
Mississipivol: If I swap noses, where would I make the cut?
I'm kind of familiar with this. I took the 1968 El Camino, cut the front clip off it and replaced that with the front clip from a 1972 Chevelle. i had a 1972 GMC Sprint (it was an El Camino with GMC markings)
is the B 17 switch kind of the same thing?
Thanks
    September 2005
Posted by richs26 on Thursday, April 24, 2014 8:01 PM
Bill Koster sells a kit to convert a 1/48 F or G to a C/D/E model.  Information can be found at Swanny's Models.  Look at Bigfoot's build for information.  If I remember right, he used an F top turret to make the remote control belly turret.  With the Koster kit, it will provide you with the correct longer engine cowlings whereas the F and G 's had shorter cowlings to enable the paddleblade props to be feathered.  The serial number on the tail would be in yellow as 12435 denoting the fiscal year of 1941, serial 2435.
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
    November 2006
Posted by Bearcat57 on Friday, April 25, 2014 6:17 AM
greentracker
you wouldn't have to cut the nose anywhere. The nose that was mentioned is the bombardier's perspex. You would simply substitute the 'G' model's for the 'F's.
    September 2005
Posted by richs26 on Friday, April 25, 2014 2:38 PM
Bearcat57
greentracker
The F and mid G glass is in no way useable for an E model as it does not have the interior framing and it is too pointed.  Koster's is the only game in town for availability of a B/C/D/E glass nose.
    November 2003
Posted by mississippivol on Friday, April 25, 2014 7:13 PM
Yeah, the "E" had more framing, and a different shape. I didn't realize about the longer cowlings, though.
    July 2004
Posted by stikpusher on Friday, April 25, 2014 8:03 PM
Just a side note, but when the B-17Es were being built, the AAF had just switched to "low vis" type markings, and any identifying marks on the OD would be in black. Serial numbers were not usually carried at that time. That would not come about at factories until 1942 with the B-17F. Usually the numbers carried would be a unit identifier and a "plane in group" number. As an example plane 12 of 15th bomb group would have something along the lines of 15BG 12 in some form on the vertical stabilizer. Plane in group numbed were assigned by the unit and did not correspond to the aircraft's serial number.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    November 2004
Posted by B299X on Friday, April 25, 2014 9:49 PM
The AFF required radio call numbers, usually refered to as 'serial numbers', from August 22, 1941. These were applied at the factory beginning in November 1941. Painted in yellow on a dark backgrounds and in black on light backgrounds and to be large enough to be read at approximately 150 yards.
Most of the B-17E's production would have fallen in this time frame as the desired production rates didn't meet the contract schedule until April 16, 1942 with the 353rd airplane, with the last B-17E being  delivered May 28, 1942 ... 49 days ahead of schedule.
HTH
Tony H.
    July 2004
Posted by stikpusher on Friday, April 25, 2014 10:29 PM
But you would need to know when the specific aircraft was built, before or after the date that serials were applied at the factory. And if that was beforehand, were they ever applied in the field in yellow or not? What regs say are one thing, applying the regs at the factory another, and wether or not they were ever applied to the aircraft in question still another.
       - Plankton
LSM
    September 2005
Posted by richs26 on Saturday, April 26, 2014 12:40 AM
They were applied in the field in yellow as witnessed in AF Colors, v.1.  Pg 85 shows B-17E's and a D obviously in yellow  Pg 89 is a 22nd BG B-26 before they shipped out from CA to Hawaii 6 Feb 42.  And the B-17E destroyed on the ground 20 Feb 42 on pg 91.  Also the three B-26's of the 77th BS of "Million Dollar Valley" fame had their serials applied by the squadron before they crashed in British Columbia on Jan 16 42 on their way to Alaska. Kermit Weeks' B-26, and the MAPS B-26 are part of this group.  But in the case of this particular B-17E, it does have yellow serials as shown by the photo from Pacific Wrecks with the date marked as Feb 23 42.
    November 2004
Posted by B299X on Saturday, April 26, 2014 1:01 AM
Yes, you're right.
In this case the information that I have shows the the B-17E being discussed (41-2435) being delivered to Salt Lake City November 30, 1941. Which puts it in the time frame of of the order to the contractors for the radio call numbers to be painted on at the factory. Whether it left the factory painted this way I couldn't be sure. My suspicion is that if it did leave the factory without the call numbers, they were added at the depot in Salt Lake City before being issued to a operational unit.
But I can see your point, there are plenty of pictures of early models of P-38's, P-39's, P-40's, A-20's, B-25's with either no call numbers or just the unit designator with the plane in group number.
HTH
Tony H.
    July 2004
Posted by stikpusher on Saturday, April 26, 2014 1:02 AM
Thanks for looking it up in Air Force Colors v.1. I was gonna check that when I got home from work here tonite ;-) I know examples of the black on OD markings were pretty common in Hawaii (and probably the Phillipines as well) at the outbreak of war. I am curious how quickly surviving aircraft were repainted to comply with the regs. I seriously doubt that was done in the PI, as the FEAF was pretty much annihilated within a few weeks. But Hawaii is a different matter altogether.
       - Plankton
LSM
    September 2005
Posted by richs26 on Saturday, April 26, 2014 1:16 AM
Some probably were repainted after May 42 with the removal of the red circle and the red and white tail bars, but some were probably never changed as in the case of of the Aleutian Tiger P-40E color photo from LIFE magazine that was in the red surround  markings in1943.
    July 2004
Posted by stikpusher on Saturday, April 26, 2014 1:29 AM
Indeed... The further forward and away from major HQs aircraft were based, the more likely they were not to be in compliance with AAF regs. SWP and CBI aircraft are prime examples of this.
       - Plankton
LSM
    October 2009
Posted by greentracker98 on Sunday, April 27, 2014 10:04 PM
Thanks everyone for the info I did some research a while back. I'll have to go back and find it again.
