Joe,
As with every Vac kit that I've done (5), there is at least 400% additional scratch building required, above and beyond what's written down on the instruction sheet, ie: fabricating your own bulkheads, wing spars, wing ribs, gear compartments, cockpits, etc etc etc.
Get yourself SEVERAL surgical scalpels, blocks of balsa wood and or Styrofoam for JIG fabrications, masking/scotch tape, filler putty, super glue (several tubes), tape measure, pencil, filler putty, multiple grains of sandpaper, filler putty, steel wool, etc etc etc.... bottom line, a vac is going to require a real "Improvise, Overcome, Adapt" attitude if going into it with "basic" building skills (heck, it requires a good I.O.A. even with advanced skills!!
). For instance.... on a Vac, you can't just glue a gear strut to the surface, you must fabricate internal bracing.... and through all this fabrication, things have to be done in the correct *unwritten* order, so it all comes together properly.
*A well stocked Spares Box will come in handy.... pretty darn near required, honestly!*
An injection kit can be constructed out of the box and made to look acceptable.... a Vac, on the other hand, requires a lot of TLC, imagination, and patience, but generally come out looking pretty good, and unique. I know, sounds intimidating, but I credit the VAC kits for making me more proficient with the injection kits!
Take care and happy modeling,
Frank
PS: Oh yeah, don't forget to get Filler Putty!
