Spirit of St Louis
    June 2013
Spirit of St Louis
Posted by Viejo on Wednesday, May 14, 2014 8:53 PM
Step one is Charlie, here is MY attempt in 1/48.  All in all, if you don't look REAL close, he looks pretty good.
At least I think so...
    February 2011
Posted by Raualduke on Wednesday, May 14, 2014 10:23 PM
Don't look like Jimmy Stewart at all.ha!  Anyway the history museum  here in saint Louis has a great  reproduction of the interior of the spirit
    November 2010
Posted by Eagle90 on Thursday, May 15, 2014 5:54 AM
Doesn't look bad to me!  I'm getting ready to dive into small figure painting myself.  I think I'll start off with some 1/35 stuff.  You doing a 1/48 is pretty brave!  I think it looks good!
Eagle90
    June 2013
Posted by Viejo on Thursday, May 15, 2014 7:01 AM
Duke, this is true, General Stewart was much, much taller.  I guess I could put some little lifts on the bottom of the shoes....
Eagle, thanks.  One of the tips I got on this forum about figure painting is to paint them as if you're dressing them.  I tried it here and it seemed to go a lot easier.  If you don't hold it right up to your eye (as the photos have done), it looks a lot better.  In fact, it's encouraged me to go ahead with more 1/48 figures.
Posted by echolmberg on Thursday, May 15, 2014 7:24 AM
I think it looks just fine.  Like you said, as long as you don't look at it with your eyeball being 0.005" away from the figure, it'll be just fine.
I've heard a lot of good things about that Spirit of St. Louis kit.  I hope to see more pictures posted as your build progresses.
Eric
    November 2010
Posted by Eagle90 on Thursday, May 15, 2014 7:39 AM
Viejo
Definitely keep posting your figure painting!  I'd like to see more and what you learn!  Thanks for posting the pics!
Eagle90
Posted by Don Stauffer on Thursday, May 15, 2014 9:01 AM
echolmberg
Eric
I felt the Revell SoS kit was a very nice kit- really enjoyed building it, and had absolutely no problems with anything.  Fit was nice, the results were great.  Loved the figure, so I built a base for it so I could display the figure standing by wing of plane.  Oh, the door is seperate and can be poised open- a real plus.
    January 2010
Posted by CrashTestDummy on Thursday, May 15, 2014 11:58 AM
I'm agreeing with Don.  It's a nice kit, and with the opening door, provides an opportunity to care a bit about the interior details.  There are some external details you can add, too that really make it a nice example when done.
Gene Beaird,
Pearland, Texas
G. Beaird,
Pearland, Texas
    June 2013
Posted by Viejo on Thursday, May 15, 2014 5:45 PM
Gene, what external details?
One of the things I'd like to figure out is how to do the cowl in the brushed aluminum finish without going to the decals (they look out of scale for me).  If I can't figure it out, it'll just end up flat aluminum.
Posted by Don Stauffer on Friday, May 16, 2014 8:54 AM
The kit needs control and trim tab rigging, easily added.
    January 2010
Posted by CrashTestDummy on Friday, May 16, 2014 4:16 PM
I found the pitot tube to be a bit out of round on my example, so I replaced it with round tubing.  The anemometer on the top of the fuselage can be livened up nicely with a little scratch-building.  I think I punched some discs out of foil, cupped them, and then epoxied them to some styrene tubing.
Then, with BMF, you can replicate the engine-turned aluminum on the cowling:
http://cs.finescale.com/fsm/tools_techniques_and_reference_materials/f/13/p/156067/1698810.aspx#1698810
Scroll to the bottom of the page.  How I did it is here:
http://cs.finescale.com/fsm/modeling_subjects/f/2/t/153678.aspx?sort=ASC&pi240=1
And, as Don pointed out, the control cables can easily be replicated on the tail, rudder and ailerons.
Gene Beaird,
Pearland, Texas
NOTE:  Insert links link is not available to me, so just copy and paste the urls listed above.  Sorry
G. Beaird,
Pearland, Texas
    June 2013
Posted by Viejo on Friday, May 16, 2014 8:13 PM
The pencil eraser, THAT's the key.
I reworked the rudder of a 19 foot sailboat one time, the rudder had a kick-up lower blade of aluminum.  While rebuilding the wooden rudder head, a friend went over the rudder blade with a steel brush mounted on a hand-drill (electric).  When she got done with the rudder blade it had the same appearance as the Spirit does on the cowl.  I knew rotations would come into play.
Now I need to find some BMF.
    January 2010
Posted by CrashTestDummy on Tuesday, May 20, 2014 11:02 AM
Welcome to the dark side!  Smile
G. Beaird,
Pearland, Texas
    June 2013
Posted by Viejo on Tuesday, May 20, 2014 11:00 PM
Speaking of the dark side, I got started and couldn't stop.  Don't know if I'll paint it or not, I kinda like it the way it is.  Decals for sure, but I think if I try to paint it properly, I'll screw it up.
Posted by Don Stauffer on Wednesday, May 21, 2014 9:18 AM
When I used the kit decals for the turned cowling, I came up short and had a gap.  Fortunately the decals were still wet, and I was able to move the decals around so the gap was on the bottom.
The kit decals have two sets of cowlings, one as on the NYP flight, the other for the subsequent tour.  I built the model as the NYP version, then cut a little strip from the tour version decals to bridge the gap.
    February 2011
Posted by Raualduke on Wednesday, May 21, 2014 4:38 PM
Looks very nice,the decals should make it pop
