Academy F15k Slam Eagle WIP
    June 2013
Posted by Reaper420 on Thursday, June 12, 2014 12:03 AM
Kick the tires and light the fires!
cml
    March 2007
Posted by cml on Thursday, June 12, 2014 1:11 AM
Whoa! Indifferent  That pre-shading looks more full assed to me.
I'm seriously impressed with how nice and neat it is! How did you get it to look so good? Did you airbrush (and if so - what airbrush, i need to get one of those!)
My attempts at pre-shading look more like a toddler has drawn over my planes with crayon.
Looking really good so far. I'll be interested to see it with the next coat on.
Chris
    January 2010
Posted by pilot47 on Thursday, June 12, 2014 1:57 AM
^+1 I must agree. That pre-shading looks awesome.
    June 2013
Posted by Reaper420 on Thursday, June 12, 2014 2:48 AM
Thanks cml and pilot47! Honestly what I used was an acrylic paint marker. I chisled the tip down to an ultra fine point and then just traced over all the panel lines. I have to admit it took me two days of about 4 hours each to do it but I like the results. I say half ass because you can see (well not in the pics) some places where the marker slipped while I was tracing. Im usually anal about it and will take the IPA to it real quick and do it again. But on here I said F it and kept going. I might end up AB'ing the next coat on tomorrow if I have the time. Pics to follow when I do!
Dre
    June 2007
Posted by Dre on Thursday, June 12, 2014 11:49 AM
I'm interested to see how that form of preshading works during painting as opposed to the usual method the rest of us use...  seeing how you traced the panel lines gives me "ideas" to use, but I need to see how it works before saying more.
    June 2013
Posted by Reaper420 on Thursday, June 12, 2014 1:55 PM
So am I Dre. Im more into the really faint panel lines, just enough to suggest that their are seperate panels. After being to tons of air shows and seeing the real jets up close, panel lines are not as exaggerated as one might think, in fact they are almost barely visible, unless the aircraft is extremely dirty. So im hoping this method will give me that effect. We will see.
    November 2008
Posted by plasticjunkie on Thursday, June 12, 2014 2:37 PM
What brand of marker did you use? You mentioned acrylic so it should be safe and not bleed out. Sharpies are a no no as they will bleed over time and ruin the paint. Testors makes an enamel marker which is safe to use but it's a bit thick tipped. As you said, panel lines look best with just a hint to show some tone variation between panels.
 GIFMaker.org_jy_Ayj_O
Dre
    June 2007
Posted by Dre on Thursday, June 12, 2014 3:14 PM
I'm thinking that if this dark preshade turns out good, you might be able to use lighter tones of grey on other panel lines for more variation....
    June 2013
Posted by Reaper420 on Thursday, June 12, 2014 3:28 PM
I use Dykem ultra brite acrylic paint markers. Very handy as they come in various colors.
    January 2010
Posted by CrashTestDummy on Thursday, June 12, 2014 3:37 PM
That was going to be my question.  Thanks, Reaper, for the reply, and keep up the great work!
Gene Beaird,
Pearland, Texas
G. Beaird,
Pearland, Texas
cml
    March 2007
Posted by cml on Thursday, June 12, 2014 6:18 PM
I'm actually wondering if this technique could be used to panel shade in 'reverse'.
What I mean is, rather than priming and using the acrylic marker, could you prime and paint your final coat then do your panel shading.
After that, you just need to mist over a few light coats of the final coat colour and your panels should still show through.
Just a thought.
Chris
    June 2013
Posted by Reaper420 on Thursday, June 12, 2014 7:59 PM
@cml- I dont see why not. Im sure you could and it would work great. I would highly advise a gloss cloat before doing it though in case you accidentally slip the marker. That way if you do, you can just use IPA or a wet towel even and wipe it off and do that particular panel again. Then hit it with a few light coats of your final coat colour.
    January 2014
Posted by Rob S. on Thursday, June 12, 2014 8:02 PM
so far so good. Very impressive build so far.
______________________________________________________________________________
On the Bench: Nothing on the go ATM
Posted by Texgunner on Friday, June 13, 2014 8:43 AM
Reaper420
Is this the same Dykem that is used in sheet-metal layout work?
"All you mugs need to get busy building, and post pics!"
    June 2013
Posted by Reaper420 on Friday, June 13, 2014 12:09 PM
I believe so. The set I bought was off Amazon. Didnt really mention sheet metal, but I also didnt really pay much attention.
    June 2013
Posted by Reaper420 on Friday, July 4, 2014 10:04 PM
UPDATE:
Been out of town on vacation for the past 3 weeks with my family, so unfortunately no bench time : ( Will be back at it in the next few days. Will post pics of the completed ordnance when I get the chance as that is really all I have had the time to work on before I went on vacation. Stay tuned!!
    March 2005
Posted by Devil Dawg on Saturday, July 5, 2014 2:40 AM
I'm liking what I'm seeing so far, Reaper. Keep it up!
Devil Dawg
On The Bench: Tamiya 1/32nd Mitsubishi A6M5 Model 52 Zeke For Japanese Group Build
Build one at a time? Hah! That'll be the day!!
