Well, I learned a good lesson recently. Never affix landing gear until your build and paint job is complete!
I was working on applying a decal on top of the starboard wing of Tamiya's 1/32 F4U-1, when it goes "crunch" and the wing drops down a half inch. The landing gear had broken at its thinnest part, just a little way above the wheel axle. Next day I repeated the stunt by breaking the other gear off in the same way!
The area available to glue is very small, just the matching surfaces of the broken parts. I was planning to use epoxy, but can anyone suggest a good way to hold the parts in position while it cures? The wheels are on the part of the gear that broke off, which makes an awkward problem to hold them in place on an aircraft lying on its back.
As a last resort, I could cut both landing gear off completely, throw them away, and display it in a flying configuration on the stand provided, but the bay doors are open which would look strange.
I can't believe that, with all my experience, I made such a blunder!
Next time, I'll buy metal aftermarket gear!
