B-25 build rescue...
    July 2004
Posted by stikpusher on Friday, July 25, 2014 6:29 PM
Between my recent completion of the Monogram 1/48 Marauder, and another thread on here about B-25s, I decided to pull this build off semi permanent sideline exile and get it finished up in the next month or so. First off, a little background on the build. I started it some 10 years ago or so in 2004 as a straight OOB build when I was getting ready for deployment overseas later that year. I was on a manic modeling spree and started for more kits in that time than life would allow me to complete. It was very much a live for the moment period in my life and there was just never enough time in the day to gt everything done. I got the interior completed, fuselage, wings and tail on then set it aside to await my return and completion. Fast forward 18 months later, and upon my return home I find that the kit had been damaged while I was away. The tail plane had been broken off, the front landing gear strut, had been snapped off, the tail gun barrels were broken off, and the nose section was about ready to come off. So this kit was sidelined, to be repaired and finished another day.
Well as I said above, a couple of things inspired me to get this one done at this time. I now had the tools and skills to repair the biggest issue, the snapped off nose gear strut. So I set out to tackle that first. Using my pin vise and some micro bits, I drilled a hole in the center of each portion of the landing gear leg, the stub that was still atteached to the wheel well sidewall, and the main strut. Then I added a portion of steel wire in the seperated leg, super glued it in place, test fitted it into the stub and saw that it would would work.
broken gear leg with wire added
hole drilled into stub and nose glued back in place
After that I glued the tailplane back in place and then the nose section after adding a spreader from sprue to counteract some warpage that had occured in the upper portions.
and now as she sits ready to resume construction... painting to begin soon. I need to add some lead shot to the nose to keep her from being a tail sitter.
U is for URANIUM... BOMBS!
N is for NO SURVIVORS...
       - Plankton
LSM
    May 2013
Posted by Greg on Friday, July 25, 2014 6:35 PM
Neat story!
Thanks for sharing the pics of the snapped strut repair. There was a thread about how to repair a broken strut the other day. Hope the OP sees this.
Very cool fix, would have been impossible (for me) to visual without the pics.
Hope you keep us posted on this one, Stik.
    July 2004
Posted by stikpusher on Friday, July 25, 2014 6:48 PM
Thanks for looking in Greg. Yes I will keep updating this thread as progress is made. Really the build was mostly done and it was so close to be ready for painting when it was sidelined.
       - Plankton
LSM
    October 2013
Posted by ajd3530 on Friday, July 25, 2014 10:33 PM
I'll be watching closely, as I have a glass-nosed J model in the plans for this fall. Always enjoy watching your work Stik.
    July 2004
Posted by stikpusher on Saturday, July 26, 2014 12:03 AM
Thanks ajd. Although you're mostly gonna see just painting on this one as the building was mostly done years ago aside from the small bits I will add at the end. And this one is gonna have a painted over glass nose with extra guns installed.
       - Plankton
LSM
    April 2014
Posted by B_one fixer on Saturday, July 26, 2014 1:56 AM
Man I don't think I could have pulled the landing gear fix off with a pin vise. I struggle with small parts like that. But I am pretty excited to see how this one will turn out.
    June 2004
Posted by seasick on Saturday, July 26, 2014 7:29 PM
 Helps to have a nice set of drills:
i602.photobucket.com/.../Hand_drill.jpg
Chasing the ultimate build.
