Completed: Eduard Spitfire Mk.IXc - late version
    October 2013
Posted by Big Blue on Sunday, July 27, 2014 4:07 PM
Hi All,
I thought I'd share some pictures of my recently completed build, the Eduard Spitfire Ixc.  I chose to model Jerry Billing's mount as it appeared over France in late June, 1944:
The overall scheme was painted with the Tamiya RAF trio of XF-81/82/83.  I used Gunze Sky for the prop and tail band.  Weathering was done with oil paints (including Windsor & Newton Transparent White for fading/streaking, black & burnt umber) and a Dark Dirt Flory wash in the panel lines & rivets.  A silver pencil "chipped" the paint, and MIG European Dust Pigment added to the dirt.
I did spring for the Barracuda resin wheels and Master Model brass cannons.  Everything else was included in the kit other than some details I added to the cockpit (which is quite nice as is to be honest.)  I used a few placard decals from an Aeroscale set to add a bit of interest.  I also added an oxygen hose made from fine wire wrapped around a bit of larger wire, as well as a wobble pump made from a bit of plastic rod and piece of photo-etch sprue for the handle.  Both are visible in this photo below (along with plumbing I added using bits of wire):
Additionally, I added a cockpit light (aluminum tubing and wire) and camera control (a disk cut from plastic rod and a small piece of aluminum tube).  Both are seen above the lower cockpit tub, near the door opening.  The tank plumbing is wire and... you guessed it, aluminum tubing:
One more to show how nice the kit's instrument panel is:
And another to show the impressive surface detail Eduard has molded:
I know there are those who don't like seeing rivets.  To my eye, Eduard nailed the appropriate level (no pun intended) as the rivets don't jump out on the finished model until you move in and really take in the details.
Much has been written about this kit, good and bad.  I have to say there are points on both sides that I would agree with.  Overall, the detail is fantastic, and the finished model is really beautiful (Eduard's contributions... I'll let others make up their own minds about mine).  Some of the complaints about the needless over engineering ring true to me: 15 pieces for the wheel bays not counting the wings?!?!  The two piece cowl requiring detail destroying filling and sanding*?  Frustrating, yes, but none of these complaints would stop me from building another Eduard Spit.
* I know there are talented modelers who will tell me that learning to properly handle seams is an essential modeling skill, and I understand that this is true.  However, on the list of things that i enjoy about this hobby, filling & sanding would be... dead freakin' last.  Behind masking canopies, behind cleaning my airbrush, behind, well, like I said, everything.  To me, filling and sanding are the fraternity hazing of the modeling world: totally sucks and has to be endured before the fun stuff, but I had to do it, so you do too.
On a more positive note, while some have had issues with the kit's decals, I had no problems with them.  They settled into all of that surface detail quite well for me, and even the stencils are printed well enough to read (with enough magnification!).  I'll leave it to others with more knowledge than I to determine if the roundels are the proper color and diameter, but I was pleasantly surprised with the quality.
The aftermarket stuff was a mixed bag for me.  Both additions are well made and very nice looking, but I had had issues with them (certainly due to my own lack of skill).  The brass cannon fairings look great and weren't a large expense, but the level of detail on the real things doesn't allow for much separation above the kit pieces.  The openings of the barrels are a bit crisper, but that is really where the difference stops (at least to my eyes).  On the downside, I have yet to find a primer that can keep Tamiya paint from falling off of brass if I look at it funny.
The resin wheels look great, and are noticeably more detailed than the kit parts.  I attached the wheels to the axles after they were already installed on the aircraft, but held the spoke portions off so I could glue the axle stubs from the inside.  Unfortunately, I should have test fit them post painting, because they did not go on for me with out some brute force effort that chipped the paint on the tires and damaged the axle mounting pegs.  As a result, the left wheel sits at a bad angle in the pictures above (I need to repair it still).
I didn't do a WIP post for this, as I wanted it to be a quick build between more complicated WWI projects.  I sincerely appreciate the effort Joe and others who post detailed logs make to share their insights here.  I did take (phone) pictures along the way, so if there is interest, I can put a post together to show the process.  (I can't say I have done anything that hasn't been seen before, or is particularly innovative, but will share if it helps someone.)  One tip I will mention is that I attached the upper cowl without the exhaust stubs using a bit of white glue.  After painting the camouflage, I was able to pop the piece off and install the exhausts and replace the upper cowl.  Avoids masking the exhausts; pretty easy.
Sorry for the long post.  Thanks for looking (and making it this far if you did!)  Questions, comments, and pointers are welcome.
Blue
    November 2003
Posted by mississippivol on Sunday, July 27, 2014 4:12 PM
Love it! Great job
Posted by Bish on Sunday, July 27, 2014 4:50 PM
Nice looking Spit. there looks like some great detail in this kit, and you have done a very nice job on it.
    May 2013
Posted by Greg on Sunday, July 27, 2014 5:12 PM
So glad you took the time to comment on the pros and cons you found. Please don't apologize for a long post. Enjoyed every sentence.
You did a wonderful job. Looks fantastic.
GAF
    June 2012
Posted by GAF on Sunday, July 27, 2014 7:02 PM
Beautiful Spit, Blue!  One to make a mother proud.  Big Smile
Gary
    February 2006
Posted by ruddratt on Sunday, July 27, 2014 10:37 PM
Excellent work on that one, Blue.  Every aspect of the the build looks top notch!  Great job on the 'pit - one of the nicest I've seen.  Yes
 "We have our own ammunition. It's filled with paint. When we fire it, it makes pretty pictures....scares the hell outta people."
    April 2006
Posted by jgeratic on Sunday, July 27, 2014 11:33 PM
Excellent looking build, and a fine tribute to Canadian Jerry Billing Yes
Will have to remember your method of attaching  the exhaust post paint, thanks for that.
regards,
Jack
Posted by Butz on Sunday, July 27, 2014 11:40 PM
Howdy Blue,
 I have eduards profi pack kit and seriously after seeing yours, I want to pull my Spit out and place it on the "to build" pile along with my eduard profi pack P-38J Wink..
 I too appreciate that you mentioned the pros and cons of the build as this will make me more aware of the build in general and what to watch out for.
 Ever kit will have it's pros and cons from various sources but at the end of the day,  as long as you had fun with the build and are happy with the outcome then that's what matters!
 I like your attention to the weathering myself and I too use various mediums when I do my weathering. Great over all build and thank you for sharing.
Flaps up,
  If you would listen to everybody about the inaccuracies, most of the kits on your shelf would not have been built Too Close For Guns, Switching To Finger
    March 2010
Posted by Nathan T on Monday, July 28, 2014 7:08 AM
Great build. Thanks for the assembly tips. I plan on building a few of these kits.
    June 2013
Posted by bvallot on Monday, July 28, 2014 8:00 AM
I definitely plan on adding a few of these to my list.  Really nicely done!! =]
On the bench:
Tamiya F4U-1  Kenneth Walsh
    June 2013
Posted by RobGroot4 on Monday, July 28, 2014 8:36 AM
Gorgeous bird, I want to get one now!
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
    October 2013
Posted by Big Blue on Monday, July 28, 2014 9:20 AM
Thanks to all for the positive comments.  I'm glad my post was helpful.
Jack, Jerry Billing is well represented by Eduard with markings for two versions of his YO-D aircraft in this kit.  Joe (lawdog114) did a great job with the D-Day version (full invasion stripes) and posted a very helpful WIP thread on these forums.
Mike, this was the profipack, 8281, and like I said, it really doesn't need any aftermarket add-ons.  As a profipack, you get some photo-etch and pre-cut masks as well.  Minor complaints aside, a very nice kit.
Nathan, BV, & Rob (and anyone else), I hope you do build one as I'd love to see the results.
As a kid, I loved the P-51, and now I'd probably say the P-47 is my favorite WWII era airplane, but nothing is as elegant looking as a Spitfire.  A high point of functional design in my mind.
    February 2007
Posted by Buckeye on Monday, July 28, 2014 11:30 AM
Beautiful build!
    August 2009
Posted by JOE RIX on Monday, July 28, 2014 12:40 PM
Gorgeous Spitfire Blue. You did a spectacular job on it for sure. Thank You for sharing not only the plethora of pics but, also the build pros and cons. I'm curious. Could you please elaborate on using the Windsor & Newton transparent white? I' W&N oils but, I've never encountered that product and I'm curious as to how you actually put it to use. Thanks.
Joe
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
    October 2013
Posted by Big Blue on Monday, July 28, 2014 2:18 PM
Thanks for the comments, Mike & Joe.
Joe, it was my first time using it as well.  As I said, I used it to fade the upper surfaces, and add some light streaking.  I randomly placed small dots of the paint on the model's gloss coated surface, and using a flat brush that is lightly saturated in odorless turpentine, I dragged the paint in the direction of the airflow until they blended in.  You don't want too much turps on the brush, or it will completely remove your work.  Just keep working the dots until you get the effect you want.  Here's what I mean:
You can see the setup on the right wing, and the results on the left.  It looks more dramatic in this picture than it does after some additional weathering with the darker oils, and a dull coat.
The gloss coat allows you to move the paint around freely, and if it is acrylic, it is unaffected by the the turpentine, so there isn't too much risk of ruining prior work.  (I use Alclad Aqua Gloss).
Hope that helps,
Blue
    January 2013
Posted by BlackSheepTwoOneFour on Monday, July 28, 2014 2:56 PM
Well done. That Spit has been on my wish list for quite some time now.
    August 2013
Posted by Jay Jay on Tuesday, July 29, 2014 9:45 AM
TY for the "extra long post "   very informative and inspirational.   I just bought my first artist oils and turpenoid and am anxious to try your techniques out.
    April 2005
Posted by wing_nut on Wednesday, July 30, 2014 6:37 AM
It doesn't get much better than that.  Nice!
Marc
