Where to get Extra 1/350 planes for carrier
Posted by Anonymous on Monday, March 1, 2004 12:01 PM
Where would I find 1/350 jet planes for a USS Saratoga CV-60 model?
I would like to add a few for realizm.
Jake
Posted by John P on Monday, March 1, 2004 1:10 PM
Tamiya makes a couple of little sets of jets for their 1/350 Enterprise, whcih they sell seperately.
When Trumpeter releases their 1/350 Nimitz soon, they will also release the very detailed jets that come with it as seperate kits.
Check www.squadron.com for both.
Posted by John P on Monday, March 1, 2004 1:13 PM
Found the Tamiya sets:
http://www.squadron.com/ItemDetails.asp?item=TM78006
http://www.squadron.com/ItemDetails.asp?item=TM78009
    January 2003
Posted by Jeff Herne on Monday, March 1, 2004 6:52 PM
Hey Jake,
There is no CV-60 Saratoga in 1/350 unless you're scratchbuilding one.
If you're referring to the old Revell Sara kit, then it's definitely not 1/350. I think it's 1/540 or some other box scale.
Make sure before you go buying 1/350 Tamiya aircraft.
Jeff Herne
Posted by Anonymous on Monday, March 1, 2004 7:00 PM
You're Absolutly right Jeff. Thanks for the save! All my models are in boxes at the moment due to a new baby and needed space in the house. Then I guess my question would be, what could I use for 1/542 crew figures? I don't mind fabricating...I just need ideas!!
Almost screwed up,
Jake
Posted by Anonymous on Monday, March 1, 2004 7:02 PM
QUOTE: Originally posted by Jake
You're Absolutly right Jeff. Thanks for the save! All my models are in boxes at the moment due to a new baby and needed space in the house. Then I guess my question would be, what could I use for 1/540 planes!?
Almost screwed up,
Jake
Posted by Anonymous on Monday, March 1, 2004 7:26 PM
oops! I'm new at this. I didn't mean to put in a quote.
What can I use for 1/540 planes is what I meant to ask.
Jake
    January 2003
Posted by Jeff Herne on Monday, March 1, 2004 8:13 PM
Good question...maybe post up on the Modelwarships.com forum, maybe there's someone with extra aircraft...You can get 1/500 and 1/600 figures from Tom's Modelworks in photoetch. Gold Medal Models also makes a photoetch set specifically for this kit.
Other option would be to cast some up...Micro-Mark makes a basic resin casting set.
www.tomsmodelworks.com
www.goldmm.com
www.micro-mark.com
Hope that helps,
Jeff
Posted by Anonymous on Monday, March 1, 2004 11:26 PM
Thanks Jeff. That will help alot. She will look seaworthy when I'm done.
Jake
