I've built this kit and I don't mind the end results. A few minor irritations as noted above. You have to be careful with filling and sanding. I found that by applying masking tape very close to the seams, filling with thin layers of Squadron white putty and then sanding with the tape still in place, I didn't lose too much detail. I never had a problem with the nose boom.
My problem came when I painted it. I was too lazy to mix paints to get the proper "midnight blue / black" colour. All I had handy was Model Master Flat Black. I was also too lazy to go to the hobby shop to buy gloss black and other colours to mix. Anyway, I sprayed the flat black and let it dry. I then shot two coats of Model Master clear gloss. I then laid on the decals using Humbrol Decal Cote. The decals silvered quite badly. Also, I had the same problem as Kingbone. The long red stripes were quite fragile. They tore in a few places. I managed to get most of them repaired to an acceptable level though.
Not a bad kit, but not without its vices.
