Cracked/broken clear repair
Posted by Bones-coa on Friday, March 5, 2004 6:37 PM
Modelers, I have a piece of clear plastic that a piece has broken off of. I CAed back together, sanded it some and brushed it with Future. Ok, apparently that isn't right. The seam is very visable. Am I just scrw** here? Is there any way to fix this? Thanks.
Dana F On the bench: Tamiya DO335B-2 with LOTS of Aires stuff (On Hold) Trumpeter A-10 with LOTS and LOTS of aftermarket goodies! (On Hold) Tamiya 240ZG (In work)
    November 2003
Posted by shrikes on Friday, March 5, 2004 6:51 PM
Ow. Hmmm... I assume that you used the non-fogging kind of CA. maybe you can take it apart again with some of that debonding agent they sell in hardware stores (though i don't know if this will for fog up the canopy). i would suggest that you PVA (elmer's glue) it back together because it dries transparent. i'm sure someone more knowledeable will come around and be of more help. Smile [:)]
Blackadder: This plan's as cunning as a fox that used to be Professor of cunning at Oxford University but has now moved on and is working with the U.N at the high commission of cunning planning
Posted by Melgyver on Friday, March 5, 2004 6:59 PM
Dana,
The seam where it cracked will aways be visible no matter what you do. Your best bet is fill the inside with clay and use it as a master to form a new canopy by heating some clear thermoform plastic or a piece of clear packaging over a candle util it gets soft and stretch it over your canopy. Unless Squadron might have some vacuform canopies for your kit. What kit was the canopy for?
Clear Left!
Mel
Posted by Bones-coa on Friday, March 5, 2004 7:08 PM
Well, actually, it's not a canopy. It's a 1/48 F-89 and the part is the radar operator's sheild. It's a stangly shaped piece and I've never in my life even attempted to thermoform.
Posted by Bones-coa on Friday, March 5, 2004 7:21 PM
Here's a pic of the part in question. Note the very prominate seam. Disapprove [V]
Posted by Anonymous on Friday, March 5, 2004 8:08 PM
I think Mel hit it on the head Dana.....you can buy the sheet from www.squadron.com....and you just heat it up over a candle 'till it's warm, and then pull it over the master (your part in question)....I've never tried it, but I've heard it works great.
Posted by Melgyver on Friday, March 5, 2004 9:10 PM
Dana,
I'll check mine out when I get home next Tues and see if it's possilbe to "form" another one. Is the whole thing supposed to be clear or just some sections of it. I have done several old Monogram canopies, Wildcat, Dauntless, and Corsair by the method I discribe with good results after a few tries. If just the "side" windows are suppose to be clear, maybe you could make a new side from clear sheet plastic. It looked like the crack ran through the left side but I couldn't tell if it wend down into the "bulged" area.
Only other option is to "beg" Monogam for a replacement part!
Clear Left!
Mel
Posted by Bones-coa on Friday, March 5, 2004 11:31 PM
It has a very fine frame. The crank went straight across the side of the thing. The crack is cloeset to you in the pic.
Is there anywhere on the net that gives a quick "how to" on thermoforming?
Posted by Bones-coa on Friday, March 5, 2004 11:37 PM
Well, I don't know if it'll do any good, but I just filled out the online order for the part on Revell's website. We'll see I guess.
Posted by Anonymous on Friday, March 5, 2004 11:57 PM
I'm looking around, it's not on aircraft resource center...i'll keep checking!!
Posted by Anonymous on Saturday, March 6, 2004 12:06 AM
Dana, here's an online tutorial on how to use squadron's thermaform
http://www.squadron.com/old/thermaform/thermaform.htm
