Vallejo Paints
    January 2015
Vallejo Paints
Posted by BlackTulip109 on Tuesday, February 10, 2015 10:39 PM
I recently got back into building models. I wanted to keep my son busy so I was giving him the old monogram 1/48 a/c kits to build, he built about 27 (no kidding) in a couple months .
So now he wants to paint them
I have a whole bunch of compucolour and Humbrol paints BUT no exhaust system yet set up. Then one night he was surfing u-tube and we came across modelers using "VALLEJO" . I was real impressed!!
Was wondering how are they to work with? Do you use them straight out of the bottle? How do you thin them? Where can you purchase them at a good price?
Thanks!!
fox
    January 2007
Posted by fox on Tuesday, February 10, 2015 11:39 PM
I have found that the Vallejo paints are very easy to work with.  If you get the Model Air line(they are for airbrushing), you just roll them between your hands to mix them, open the cap, put as many drops as you need in the paint cup and spray away.  When finished, run some Windex through the brush followed by a few drops of distilled water and your ready to either change color or close up shop for the night.  If you use the other lines for regular brushing, you just thin with a few drops of distilled water.  Clean the brush with Windex.  That's all that there is to it.  They work great and give a great finish.  They are a little pricey but well worth it.  You could also use regular craft paints like the ones at A.C.Moore or Jo-Ann fabrics.  They get thinned with water and cleaned up with Windex also.  They are a lot cheaper.  Usually $1 to $1.50 ea. and sometimes a sale of 3 for $1.
Hope that this helps.
Jim Captain
 Main WIP:
    August 2005
Posted by Phil_H on Wednesday, February 11, 2015 12:20 AM
In my experience, Vallejo ModelColor will benefit from a nice flat primer coat, particularly if brush-painting.
    January 2015
Posted by BlackTulip109 on Wednesday, February 11, 2015 9:40 AM
Thanks everyone didn't know about the distinction of Vallejo. I will look for the Model Air line
    August 2012
Posted by AndrewW on Wednesday, February 11, 2015 11:12 AM
BlackTulip,
I use vallejo's paints exclusively, short of their primer.  Their paints are very 'rubbery', and so is their primer.  While this is easy to work with in the paint, not so much with a primer.  For this reason, I use AK Interactive's primer, and Vallejo paint.  This all behaves very nicely together, and is harder to knock the paint off with a finger nail.
I order all my supplies for painting through the Sprue Brothers website.  Do yourself a favor when you are there, and look up their thinner and their airbrush cleaner.  While their paints are advertised as ready to spray, I find the consistency varies when comparing light and dark colours, some are very thin, some very thick.
Windex contains ammonia, which is the cleaning agent used for most acrylic paints.  Vallejo reacts very badly with ammonia or alcohol.  It turns to a jelly, clogging your airbrush.  Their own thinner reacts nicely with their paint, and their cleaner cleans the brush nicely.  I have two bottles of cleaner on the go all the time, one straight and one mixed fifty fifty with tap water.  I use the mix in between colours in a single paint session, saves on the cost of cleaner and is effective, and use the straight one at the end of a paint session.
Vallejo's colours are usually very accurate, spray nicely and dry quickly for me.  If you're using masking tape over top, do so carefully, their model air line is 'delicate'.  There are tricks to working with it.
Life is hard, it's even harder when you're stupid - John Wayne.
    January 2015
Posted by BlackTulip109 on Wednesday, February 11, 2015 11:25 AM
WOW Thank you very much for the information!!
    March 2013
Posted by patrick206 on Wednesday, February 11, 2015 1:21 PM
Hi, BlackTulip - I think it's great that you're sharing your modeling hobby with your son, good for you. 27 in 60 days, wow, if I'm really turning them out I might do that many in 2 or 3 years.
Vallejo Model Air does spray nicely, clean up is easy and the finish does appear good. But there are some individual characteristics that really are not stellar. As was said, never mix or clean with alcohol, the reaction will definitely not go well. I only thin with their own thinner, I clean with lacquer thinner, very effective and far less costly.
Speaking only for myself and from personal experience, I find Model Air to be somewhat touchy as to the use of their thinner. My first go at it was a quick test on scrap material. I just put a few drops of thinner in a cup load, mixed it well and sprayed at my customary 12-18psi. It looked great, but it stayed slightly tacky to the touch for about a week, then it set up like any other acrylic would, but was a bit easier to lift with tape and mar with a finger nail.
Sprayed straight from the bottle it still looked fine, went on well and seemed to dry about as quickly as I am accustomed to with Tamiya, but it still wasn't quite as durable in handling.
Vallejo says for preparing to pour Model Air, just "roll it between your hands." Again from my experience, that is just not sufficient. At one point I removed the cap, (just push sideways on the cap and it will lift an edge, then with finger nail lift it the rest of the way off.) Using a small metal dentists spatula I stirred well around the entire bottom of the bottle, then saw the usual glob of unmixed paint solids on the spatula. Then I poured all of the contents into a small cup and stirred with the Badger electric mixer, until a consistent blend was reached. At that point the paint was a bit thicker than I like to spray, so a couple of drops of thinner was added and it sprayed OK, but still seemed to take a few days to set up well.
So, I found that I had a more durable finish by waiting a couple of days, then spraying a clear finish over it and it wasn't so easily damaged by handling for masking or decaling. I have used Tamiya for a few years now, and have since returned to it. For as nicely as Model Air sprays and looks, it just seems too touchy for my use and also I have to order it, my local shop only carries Tamiya for acrylic.
I read great things from others on FSM about different acrylics, next I'll try some of them, just to see. When you do spray your Model Air, remember to use light coats if you do add thinner. Hope it does well for you.
Patrick
    January 2015
Posted by BlackTulip109 on Wednesday, February 11, 2015 2:28 PM
Thanks Patrick for the kind words about Joey and for the help on the Vallejo Paints.
Joey will work on model airplanes whenever he can slip in the time. My wife uses it as a means to get him to get his homework done and do well in school.
Most of the kits as I mentioned are the monogram 1/48 kits and those SMER 1/50 scale and a bunch of Supermodel Italian 1/72 and some testors I had up on a shelf., as well as some off brand Russian 1/72 WW2  a/c kits. He has really improved and getting better. He's workingon a 1/32 Hellcat (an old kit I paid $10 for years ago- not my better kit) and he's doing O.K.
But as I mentioned he wants to paint them and I didn't want him using solvent chemicals until we can go outside.
I will go ahead and give Vallejo a try. I learned long ago to clean my air brush with "acrylic lacquer thinner" you get it at automotive shops and it does a phenominal job!! I have also used it to thin Humbrol and those British paints( Acuscale and Precision) it "bites" the plastic and dries really fast!! But NO way I'll use it in the house!!
Thanks again for the help I'll stay in touch and everyone know how things are coming along
    April 2006
Posted by waynec on Wednesday, February 11, 2015 5:41 PM
AndrewW
BlackTulip,
What Andrew said. I prime with ACE Hardwre NOW for a primer. the regular (white cap) is thick and needs to be thinned. i also thin the air (black cap) a bit. nboth brush paint nicely for touchup work. i like the dropper in the bottle. i suggest spending the extra bucks for Vallejo air brush thinner and air brush cleaner. AS STARTED DON'T USE WINDEX. it will gum up the works. i have masked with silly putty with no problems. for references look up 1/72 JAGDTIGER and 1/35 LOW SIDE GONDOLA. both were done with Vallejo.
Никто не Забыт    (No one is Forgotten)
Ничто не Забыто  (Nothing is Forgotten)
    August 2012
Posted by AndrewW on Wednesday, February 11, 2015 7:32 PM
Like Wayne, I have used silly putty for masking without issue.  When I am using masking tape, which is fairly often, I use mostly Tamiya tape and sometimes Frog Tape.  In either case, I stick it to my hands, pants, forehead several times to knock down the 'stickiness' a lot.  In this way, I rarely peel up paint.  With Tamiya tape, I stick and lift 12 to 20 times before I use a strip.  It might help the young fellow when painting, save him some frustration.
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, February 12, 2015 8:38 AM
Check your local Hobby Lobby stores. They carry Vallejo Model Color paints. Get them while they're still have them. HL are clearing them out $1.79 ea.
    August 2012
Posted by AndrewW on Thursday, February 12, 2015 4:40 PM
Model Color is meant for hand brushing, while Model Air for airbrushing.  I've heard of folks airbrushing Color, but with a LOT of thinner.
    May 2012
Posted by pilotjohn on Thursday, February 12, 2015 7:24 PM
Hobby Lobby is dumping them you are saying?
John
    January 2013
Posted by BlackSheepTwoOneFour on Thursday, February 12, 2015 9:33 PM
Seems to me they are pilotjohn. Gonna head back there Monday to see if any more are marked down to $1.79 each. The last time I was there a handful of Vallejo paints were on clearance and other Vallejo colors weren't. I did grab the last 2 bottles of their thinner medium.
    January 2015
Posted by BlackTulip109 on Thursday, February 12, 2015 9:55 PM
WOW
I better get over there soon!!
Thanks for the heads up!!
    May 2012
Posted by pilotjohn on Friday, February 13, 2015 6:40 AM
Thanks for the update.  I have a local shop that carries them also, but he is a much further drive.
John
    November 2008
Posted by plasticjunkie on Friday, February 13, 2015 7:31 AM
I'm not a fan of acrylics but Vallejo does brush well on top of a primer. I called my local Hobby Lobby and the gentleman that handles the hobby section said they are discontinuing certain colors but not the entire line. He even checked for me what discontinued colors were available.
As far as thinning the Model Color line, I use Testors Universal Acrylic Thinner and works just fine.
 GIFMaker.org_jy_Ayj_O
    January 2013
Posted by BlackSheepTwoOneFour on Friday, February 13, 2015 2:31 PM
plastic junkie - what colors is Vallejo discontinuing?
    November 2008
Posted by plasticjunkie on Friday, February 13, 2015 3:57 PM
black Sheep-Recalling from memory
Cavalry red, reflective green, German uniform green, British uniform tan, buff, sandstone(?) either red or brown leather, a light yellow, gloss white. I'm certain there are a couple more but can't remember which.
    January 2015
Posted by BlackTulip109 on Saturday, February 14, 2015 10:38 AM
Even though it's snowing like Siberia here in northern Indiana I am heading to Hobby Lobby to see if they have Vallejo paints
Thanks again everyone.
In addition I have discovered at Menard's the Rust-o-leum spray paints that canbe applied to plastic!!!
I bought some as many of the colors are very close to the British, German and Italian World War 2 colors.
I painted a 1/72 Cr-25 we have been working on and it was a Wow'er !!!
    October 2014
Posted by lucianmillo on Saturday, February 14, 2015 3:23 PM
BlackTulip109
Vallejo Paints:
Spray distance is about 4-5 centimeters from the surface of the model, and for fine details the pressure is lowered to 1.2-1.0 bar. After each 20 seconds of work the tip of the airbrush is swiped with an ear bud dipped in isopropyl alcohol to remove the clots and residues that might form.
The Vallejo Model Color paints work best when diluted 1 to 1 with the Vallejo Airbrush Thinner new formula (71161) . Using any other thinner leads to various problems, such as paint clotting or having trouble adhering to the surface of the model, so use ONLY the Vallejo thinner and nothing else. To avoid a grainy texture due to the paint drying while sprayed, for every 6 drops of paint (diluted 1 to 1 with thinner), I add 2 drops of Vallejo 70597 Retarder Medium.
Vallejo Model Air paints are superior to the Vallejo Model Color range, will need one part thinner for three parts paint and will work very well without adding Retarder Medium.
Let me tell you a little secret I discovered while working with Vallejo acrylics: if you rub the surface with a piece cotton cloth about two minutes after it was airbrushed, the sheen of the paint will change from almost flat to a satin/gloss finish, without changing the other properties of the paint.
I strongly disagree with the so-called "pre-shading" tehnique that sadly has gained such a widespread use. It is not realistic and counter-intuitive. In real life the paint degrades from the outside (weather, sun, scratches and chipping, and so on) not from the inside as this "pre-shading" would lead you to believe.
I begin with the base coat of paint as accurate as possible and on top of that various filters and washes are applied.
My base wash is done from grey pigment, dissolved in water, on top of which other filters are applied. For filters the acrylic Vallejo ranges are used, both Model Color and Vallejo Air.
    January 2015
Posted by BlackTulip109 on Sunday, February 15, 2015 10:32 AM
Made it out to Hobby Lobby yesterdayFeb14
Lots of paints gone.
The manager said they are just thinning some old stock out BUT plan to expand MORE!!!!!
At $1.79 it was a great deal. I bought a whole bunch. I also discovered an acrylic paint called
"AMERICANA" at only a $1.00 a bottle I took a chance as many of the colors came close to the WW2 Axis and Allied colors.
When I came home we tried them out on some of those 1/50 SMER kits my son built. They dried up to look really nice!!
My questions are
With the Vallejo what do you thin them with
Someone said distilled water?  IS Windex good too?
I love how they brush very nicely. Clean up is a God send. I primarily want to use acrylics because with winter in full force here we can't use the outside to paint with an airbrush and I don't want my son messing with the "chemicals" which stink up the house.
Also he can't ruin my paint brushes.
Thanks for all the advice from all of you I am learning a lot!!
    January 2015
Posted by BlackTulip109 on Sunday, February 15, 2015 10:35 AM
On one of the SMER a/c we primed it with a very light dusting from those RUST-O-LEUM "for plastic too" spray cans then this morning we hand painted with some Vallejo colours, looks really nice so far.
Will report later on this experiment!!
Thanks
    January 2015
Posted by BlackTulip109 on Sunday, February 15, 2015 10:39 AM
Thanks for the help
While at Hobby Lobby I didn't see the thinners and retarder you mention.
I am going back today 2/15 so I'll look for them.
BECAUSE
As you said the paints start getting a little thick coming out of the bottle
BUT still I like how they look once they dry.
    May 2012
Posted by pilotjohn on Sunday, February 15, 2015 1:54 PM
BlackTulip109;
You will find a lot of answers on these forums about thinning (ie extending), cleaning and priming, etc.  I think for someone first starting out (and I did this too) you are best served using the thinners and cleaners that come from the same manufacturer as the paint. Yes, it may be more expensive, but you want to learn processes with the best possible chances for success.  If you put rancid milk in your coffee why spend a lot of money on beans and a good grinder?  You have hopefully read that you don't put alcohol into Vallejo as it makes a gooey mess.  That doesn't mean Vallejo paints don't work.  If you stick with their thinner, you won't have that problem.  As you get "good" with your technique you can expand into a different area.  The product that works the best for you is the best for you.  All these companies make products and they have to work as they are still in business and still making them.
I almost got paralyzed by doing all the analysis of what to do and what is best and suddenly found myself not building, but just reading and thinking about buying new things.  So..,  to answer your question, use Vallejo's thinners and cleaners if they are available to you.  They both work and that is there intended purpose.  Windex, a no-no to me as a thinner as it is used by lots of folks to clean their airbrushes.  Windex is ammonia and not something that mixes well with paints as it is used as a cleaner.
I think you will learn to like acrylics and they do make the indoor world a whole lot more fun.  Good luck!
John
    January 2015
Posted by BlackTulip109 on Sunday, February 15, 2015 2:25 PM
PilotJohn
Thank you very much for the help. I am going to Hobby Lobby today and will look for the Vallejo products you mention if I can't find it I will hold off on using the product  and order it on line I will check with ebay unless there is another source.
On the U-tube I have seen a lot of the European modelers using Vallejo and I really like the results I saw and LOVE the fact I can use it in the home and clean up so easily.
Thank you again.
I did a lot of searching to find the product and in my search I discovered this Forum so you have my word I will use the product as directed and report back.
Thank you again!!
Very Appreciative
Black Tulip109
    January 2015
Posted by BlackTulip109 on Sunday, February 15, 2015 9:40 PM
Thank you lucian!
I made note of what you suggest and will pick those items up!!
    January 2015
Posted by BlackTulip109 on Monday, February 16, 2015 9:52 AM
ALL of you folks have been awesome in your help I have learned a lot and can't thank you enough.
One of you suggested "Sprue Bothers" and their prices are pretty good. I ended up findin and Italieri 1/48 CR-42 for $10!! that's a deal!!
Anyway found some Vallejo paints that Hobby Lobby didn't have and ordered the Vallejo Thinner-Thanks John I took to heart what you had to say I found a ebay site that had the Retard medium #70597 and ordered that.
Unfortunately Hobby Lobby didn't have the Thinner and Retarder.
I have suspended painting until I receive these products.
In the mentime I have Pine Wood Derby car to get ready for Joey this coming weekend so the models are on hold.
Thank you all I will keep you all posted !!
    January 2015
Posted by BlackTulip109 on Monday, February 16, 2015 11:00 PM
Thanks John
Finally was able to get a bottle of Vallejo Air Brush cleaner. The retarder is another story, "HArd to Get".
But I think I found a place that has it.
Alex Modeler and a few other U-Tube guys I asked said to thin with distilled water and it also acts as a pretty decent retarder, BUT they ALL emphasize DISTILLED WATER. I can see whywith all the chemicals and minerals in our drinking water.
I hand painted tonight with the Vallejo and it sure looks great when it dries.!!
    January 2015
Posted by BlackTulip109 on Tuesday, February 17, 2015 1:15 PM
This morning I checked out the aircraft I hand painted with the Vallejo.
I was really impressed !! Can't see any brush marks and the color looks like it blended into the plastic!!
And this is only from brushing!!
Using an old rag I lightly and gently polished the wings and it produced a nice "sheen". I can tell i am going to like this paint.
When my thinner and retarder arrive I will airbrush it and see what happens.
If this stuff really works I may sell off or give away a chunk of my enamels.
What is appealing to me is the short set up and preparation time,and the clean up is SO easy!!
