Cabling Question
    December 2014
Cabling Question
Posted by Dropkick on Tuesday, March 31, 2015 5:04 PM
Hi, I just picked up a copy of Eduards Nieuport-17. It didn't come with any cabling and no suggestions either. What should I use for cabling up this aircraft? Thanks
Posted by gregbale on Wednesday, April 1, 2015 6:55 AM
Could depend on what scale you're working in. Lengths of stretched sprue, attached with white glue, works pretty well for 1/72. For larger scales nylon thread (or fishing line), or a stretchable product called EZ Line, seem to be the popular choices. Both of the latter are usually attached with super-type glues.
Good luck.
Greg
George Lewis:
Posted by Don Stauffer on Wednesday, April 1, 2015 9:01 AM
Just be sure you color it properly.  Flying wires should be a medium gray, not a stark white nor black.  Many threads, including monofilament nylon, can be colored by markers.
    May 2014
Posted by SubarooMike on Wednesday, April 1, 2015 10:39 AM
Don Stauffer
Just the flying wires?   Not the landing wires?  Wink
But silver sprue works great.  A two-inch piece can yield 3 feet  of rigging/antenna wire goodness!   But the benefit of EZ line is if you bump it, it will stretch a little.  The stretch sprue will break.
    September 2006
Posted by the Baron on Wednesday, April 1, 2015 12:01 PM
Along with the scale, it depends on the particular subject.  If your aircraft was rigged with the flat steel "RAF" wires, then you might also use the finer sizes of Evergreen strip, especially for 1/48 or 1/32 scale.  That dawned on me, when I first saw Accurate Miniatures' F3F kits.  The F3F had RAF wires, and AM supplied photo-etched parts for the rigging.  I realized that the thinnest strip stock that I had would look good as that wire stock, too.
Posted by Don Stauffer on Thursday, April 2, 2015 8:36 AM
The scale size of bracing wires need to be so small that it is hard to find anything the right size in flat or airfoil shaped materials.  However, I believe the scale wire would be below the resolution limit of the eye at reasonable viewing distance, so I don't think the shape is so critical.  Most of the attempts I have seen at using real wire, PE, or styrene has looked well oversize.
To me, as I remember bracing wires, it is about .125 or smaller, except for the single strand forged stuff that seems to be up to about .250 in the biggest direction.  So for, say, 1:48 scale, that is about three mil and about six mil.  Those are pretty small dimensions.
    May 2014
Posted by SubarooMike on Thursday, April 2, 2015 8:52 AM
Don Stauffer
You can stretch sprue until it's the diameter of a fiber from a T-shirt.  Just have to get the technique down.
    September 2012
Posted by GMorrison on Thursday, April 2, 2015 10:05 AM
Search out the FSM World War 1 Aeroplane GB on this site. Some really good modelers who used the whole gamut of products.
About the only constant- you shouldn't use sewing thread.
    September 2012
Don Stauffer
And flight line?
    August 2014
Posted by goldhammer on Thursday, April 2, 2015 2:59 PM
GMorrison
Don Stauffer
And flight line?
stained concrete gray............But I need about 30 yards of flight line to complete the diorama.Bow Down
