Eduard 1/48 SSW D.III kit #8256 New mold
    October 2004
Posted by StephenLawson on Sunday, May 3, 2015 2:52 PM
Eduard's 1/48 scale kit #8256 is their 100th kit issue. While being a "HiTech" and finely detailed plastic mold it has garnered some harsh critisicm concerning their on-going struggle to get the colors and layout right on their German Lozenge camouflage. Since 1992 Eduard has made various attempts and has come close once. For some reason after that they veered away sharply. I will be using aftemarket decals to finish this kit. 1. Because I purchased it with my own money.
Eduard’s own Vladimir Sulc has commented, ". . . The SSW D.III was outsourced (to another company) and unfortunately it shows, and so we will be doing the SE 5a ourselves. . ." While the kit has a high degree of detail, I will try to give you a head’s up on what you may want to fix.
This is my build of 8349/17 from Eduard's 1/48 new mold #8256. The national & personal markings are from Eduard's first issue #8001 (back in 1993). The lozenge is the fine set from Aviattic. The wood grain for the fuselage is a decal set from HGW. I deleted the "new" Eduard engine for an OOP resin item. 8349/17 was from Kest 4b and was turned over to the French at the EOW. It was one of the early production machines sent to JG II and returned for refitting. It was then assigned to Kest 4b a home defence unit. After the war's end it was photographed in French hands.
Stachel...unconfirmed by Armee means unconfirmed!!!!
Posted by jeaton01 on Monday, May 4, 2015 10:34 PM
Thanks, Stephen.  The wings look like they are rather thick, is that so?  I built the old kit and I don't remember having that issue.
John
    October 2004
Posted by StephenLawson on Tuesday, May 5, 2015 2:07 AM
Greetings John,  I have done both recently.  The new mold seems much better than the old.  (But the kit lozenge is wretched).  The plastic trailing edge is thin but base paint the basic lozenge covering and the edging tape puts a lot in one area. The Aviattic ribbing & edging tape sheets have a white backing where the basic cover lozenge is translucent.  The colors are spot on for the factory fresh colors.
The wrap around effect of the lozenge is deceptive and makes the trailing edge seem thicker but its not really.
    October 2004
Posted by StephenLawson on Wednesday, June 17, 2015 9:26 AM
By the way John here is the early build #8001.  Its in a diorama called "Our best man is on it"  It took a respectable 1st in the recent Region X con here in Denver.
    October 2004
Posted by StephenLawson on Thursday, September 17, 2015 2:37 AM
I began the other two Eduard 1/48 SSW D.III builds that I marked as Marine Feld Jasta aircraft that may have been among the machines turned in at Nivelles at the EOW.
    June 2014
Posted by BrandonK on Thursday, September 17, 2015 9:10 AM
Nice builds. I love those older wood and canvus birds. I need to start adding some to the stash. Thanks for sharing with us.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    October 2004
Posted by StephenLawson on Tuesday, September 22, 2015 4:53 PM
Well ya'll here is the result of a dual Eduard 1/48 SSW D.III (kit # 8256) build. I used the HGW dark wood decal panels (modified) and a mix of the Aviattic 1/48 factory fresh and faded 5 color lozenge. The motors are the Eduard resin item and the Instrument gauges are all Eduard aftermarket PE.  The first build represents a machine from Marine Feld Jasta IV at the End of War. Possibly D.3042/18.
The build represents a machine from Marine Feld Jasta II at the End of War. Possibly D.3011/18.
    June 2003
Posted by allan on Wednesday, September 23, 2015 7:59 PM
Nice. Its not often you see a wood finish on a plane.
No bucks, no Buck Rogers
