Revell's F-15C--major fit issue here, what would you do?
    January 2006
Posted by dirkpitt77 on Wednesday, May 6, 2015 1:08 PM
If anyone's built the Revell F-15C, you'll recognize the area I'm talking about here. I seem to remember having this same issue when I built this as a kid some 25 years ago. Back then I didn't care and just glued it up, stepped seam and all.
Anywho, where the forward fuselage with cockpit and nose gear fit to the main fuselage, there is a size difference in the diameter of the mating surfaces. I'm thinking it's at least 1/8 or 1/4 inch.
Top seam would be manageable:
 . by theirishavenger, on Flickr
But the bottom....oh my:
Here's the step in the instructions for clarity:
Sanding, grinding and putty ain't gonna git it here without a major contour change. I thought of bracing the inside of the rear fuselage to push the mating surface outward, closer to a flush fit, but it strains the other seams I've already glued so much they are threatening to crack.
I contacted Revell to see if they'll comp me a kit. Their F-15E is about the same price range, so we'll see. This might be the first kit I've had to toss in quite a while. Pretty bad.
Chris
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    September 2012
Posted by GMorrison on Wednesday, May 6, 2015 1:50 PM
Horrible!
Get the top right, then approx. the bottom.
About all I can think of is to try this:
    March 2010
Posted by Nathan T on Wednesday, May 6, 2015 7:17 PM
Man, that is a huge gap for a spreader bar inside the rear fuselage...Throw that kit away and build their Strike Eagle. You won't look back.
    November 2003
Posted by mississippivol on Wednesday, May 6, 2015 8:01 PM
I'm game; Morrison's idea looks promising. You could also, possibly, get the "E" and splice the upper fuselage of the "C" to it....
    January 2006
Posted by dirkpitt77 on Wednesday, May 6, 2015 8:12 PM
You know, I'm not so in love with the 'C' model that I won't buy an 'E'. I read some reviews on that Strike Eagle and it's looking good. I can get it at Hobby Lobby with a coupon, too.  ;) I'll wait to see if Revell is going to help me out, first.
Chris
    November 2003
Posted by mississippivol on Wednesday, May 6, 2015 8:27 PM
Although you may have to put it into "File 13" eventually, it's still worth a shot to see what you can do with it.
    September 2012
Posted by GMorrison on Wednesday, May 6, 2015 8:57 PM
You guys may remember Eddie Miller. He built amazing hybrids from parts. Do a search in aircraft for Hogzilla.
    May 2014
Posted by SubarooMike on Wednesday, May 6, 2015 9:04 PM
GMorrison
Is he still an active user?
    September 2012
Posted by GMorrison on Wednesday, May 6, 2015 9:08 PM
Not for years
GAF
    June 2012
Posted by GAF on Wednesday, May 6, 2015 9:27 PM
You know, it doesn't matter what kit it is... someone on FSM has built or asked about it.  Smile
http://cs.finescale.com/fsm/modeling_subjects/f/2/t/37796.aspx
    August 2008
Posted by tankerbuilder on Thursday, May 7, 2015 8:04 PM
You Know ;
   Dirk - I can't remember having that problem with the Strike Eagle . Although There is another method I have used on their large F-4 model . I make a plug just small enough to fit inside the back part , with about a half of an inch of it sticking out .Then when I bring the parts together there is an area I can clamp on to close it up !
    June 2013
Posted by RobGroot4 on Thursday, May 7, 2015 8:41 PM
Make it a dio sitting on the Tarmac or on a runway or something with the aircraft secured down to the surface.  You'll never be able to see the underside and you can just ignore it and not go through all the pain.
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
    January 2006
Posted by dirkpitt77 on Saturday, May 9, 2015 4:41 PM
I think RobGroot wins it. I think I'll slap it in a sand dune diorama and call it a Gulf War casualty or maybe a sci-fi post-apocalyptic type scene.
Thank you guys again for all your help.
Chris
    August 2008
Posted by tankerbuilder on Saturday, May 9, 2015 4:47 PM
Oh , Good heavens ;
   Don't do that . Display the airplane in pieces like it's a research and testing bird . All sorts of identifiable F-15 all over the place !
    March 2013
Posted by patrick206 on Saturday, May 9, 2015 6:12 PM
I cannot imagine that such a GLARING fit issue, could have gotten by the final production authorization inspections, then the molds being used for kit deliveries to customers. So I have to think it's some sort of warp problem, usually due to molded parts not allowed to cool sufficiently before boxing, or placed on other parts too quickly right out of the mold.
Some moderate heating, (hot water, hair dryer or under a light,) with repeated attempts in stages, may well reveal a salvageable part without surgery. I've had great luck with some reshaping that way, often it just might take a bit of "coaxing."  The problem for me has sometimes been to be able to determine which part has the warp, it's not always instantly recognizable, at the start all you know is "something just ain't right."
I also second G Morrison's example, that should do it.
Maybe R/M will send you replacements??? I hope to read that you saved it and will show us, you're a heck of a builder and I always enjoy seeing what you're up to. If you bin it, you'll always hate yourself. Best.
Patrick
    January 2006
Posted by dirkpitt77 on Saturday, May 9, 2015 7:43 PM
Maybe so. I'll take another look. I got hold of someone on Revell's Facebook page who said they'd email me very shortly. That was Thursday. I guess their 'very shortly' and my 'very shortly' are two different things. If I hear from them we'll see what they say and go from there. I have a TBM Avenger to finish up too, so not sitting around to wait.  Beer
Thanks all, for the help so far,
Chris
    June 2013
Posted by RobGroot4 on Saturday, May 9, 2015 9:20 PM
Thinking more on this, I think Patrick may be onto something.  Maybe the boiling water trick?  heat couldn't make the bottom any worse, and if it does, you can always glue it to a runway with a bomb-loading trolley underneath to help hide the seam.
Groot
Posted by Ish47guy on Thursday, May 21, 2015 11:51 PM
A little late to the party, but when I built this kit a ways back, I put spreaders in three areas to get the fuselage pieces to line up better:
I also added a small nut in the radome for weight.
