Italeri/Accurate Miniatures TBM-3 Avenger instructions? Turret issue
    January 2006
Posted by dirkpitt77 on Friday, May 8, 2015 8:16 PM
Hey folks,
Italeri's instructions are terrible, and I'm on the home stretch, but need help with the turret. It seems one must glue one half of the turret glass to the already assembled turret, then glue the other half of the glass on. Is this correct? Italeri's instructions would have you glue all turret glass together, then fit over the turret. This method doesn't seem to work due to stuff being in the way of a clean slide down onto the turret. Can anyone give me a clue as to what AM intended here? Google search is only turning up old threads.
Thanks!
Chris
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    August 2005
Posted by Phil_H on Friday, May 8, 2015 8:47 PM
    January 2010
Posted by ajcmac on Friday, May 8, 2015 8:59 PM
Chris
Already built the Academy model also a CA rebox as the Italeri model.
I glued the two transparent pieces.
After painted.
And finally in place.
I hope this helps.
Regards
ajcmac
    August 2008
Posted by tankerbuilder on Saturday, May 9, 2015 4:49 PM
Oh ;
Thassa nicea boidie .Kin I have it ?
    May 2013
Posted by Greg on Sunday, May 10, 2015 10:18 AM
Chris, I have a copy of the original AM instructions as a PDF. I'm not sure I could have assembled the turret assy on my Academy rebox without them. There is a page on just the turret.
I don't know how to post one page from a pdf here, but if you want to PM me your email address, I'll email the entire AM instructions PDF to you if you want.
    January 2006
Posted by dirkpitt77 on Sunday, May 10, 2015 12:03 PM
Thanks for the offer, Greg. I'm fixed now. I got it figured out late last night, finally.
I think I must've mis-assembled the lower turret assembly somehow. The glass portion was just not sitting down on the notches at the sides like it was supposed to. The molded pivots on each side for the gun, the curved shield in front of the gunner, and the gunner's armored headrest were preventing the glass from resting evenly on the notches. I ended up grinding off the headrest, and grinding down the sides and front until the glass could be dropped into place correctly.  Here's a pic. Ground areas in red, notch and tab align points in yellow.
Probably just ham-handed assembly by yours truly, but I guess that's the way it goes sometimes.
Chris
    May 2013
Posted by Greg on Sunday, May 10, 2015 8:46 PM
Glad you got it sorted, Chris.
That turret assy had me laying awake nights trying to figure it out a couple years back.
