How to balance a 1:350 scale E2C Hawkeye for the Enterprise
    November 2008
Posted by Arespontus on Saturday, May 16, 2015 2:54 PM
Hello
I am working on an 1:350 scale E2C Hawkeye for the aircraft carrier  CVN 65 Enterprise but it is back-end heavy and would like a tip on how to weigh the front-end of the Hawkeye. I tried a little bit of putty but that didn't help.
Any Suggestions?
    September 2003
Posted by checkmateking02 on Saturday, May 16, 2015 3:21 PM
It might take something heavier than putty--maybe a b-b or a small fishing weight?  I'm not familiar with how big the Hawkeye is, or whether you can access the insides.
If everything else fails, you could cut a short piece of stretched sprue, drill a hole to fit it in the underside of the plane where it might not be too visible; then glue the sprue in place to brace the plane on its nose gear.
I did this with a tail-heavy B-24, using a straight pin.  In the photo, you can just see it ahead of the ball turret.  Even in this 1/72 kit, I couldn't seem to load it with enough weight to make it sit right.
Whatever you try, good luck with it.
    January 2006
Posted by dirkpitt77 on Sunday, May 17, 2015 12:51 AM
I would just use a tiny dot of super glue or white glue on the nose wheel. If you're reluctant to secure it permanently to the deck, all it would take is a little tug to pop it free should you choose to move it.
Chris
    "Some say the alien didn't die in the crash.  It survived and drank whiskey and played poker with the locals 'til the Texas Rangers caught wind of it and shot it dead."
    April 2015
Posted by Wolfman_63 on Sunday, May 17, 2015 8:16 AM
I used a small drill and drilled a couple of holes from the bottom near the front then I CA glued small pieces of solder in the holes. If I recall it took 3 small pieces to weigh the from down. I also had the PE props and made the spinner out of solder as well.
Website:
David's Scale Models - https://www.davidsscalemodels.com
    November 2008
Posted by Arespontus on Monday, May 18, 2015 12:47 PM
Thanks, I ended up using some clear sprue and glued underneath the Hawkeye where it isn't to visible
