1:72 F-18 "Blue Angels" Revel 'snap tight' build log.
Posted by gregbale on Monday, June 15, 2015 9:13 PM
Following with interest. I did the Hobbyboss "simplified" Blue Angels F-18 which, while not snap-tite, was about the same degree of difficulty (or lack thereof). Should be fun to see what you do with yours.
Greg
George Lewis:
    November 2003
Posted by mississippivol on Monday, June 15, 2015 9:31 PM
Should build up ok; there may be some gaps in the fuselage that you'll want to fill in.
    June 2013
Posted by RobGroot4 on Tuesday, June 16, 2015 2:59 AM
There will be gaps, large ones.  I built this with my daughter as a toy for her to play with (spent all of about 5 minutes snapping it together and applying the "decals" [pronounced stickers]).  The canopy was pretty loose as were the vertical stabilizers.  With some effort you should be able to make it into a pretty decent aircraft, but it will definitely require effort.
Groot
"Firing flares while dumping fuel may ruin your day" SH-60B NATOPS
    April 2015
Posted by UlteriorModem on Tuesday, June 16, 2015 4:16 PM
Gah those are 'stickers' did not notice. I am not sure how far I will go with this kit.
    November 2010
Posted by john087 on Thursday, June 18, 2015 9:10 AM
I though the gaps on my 1/48 has f18 were bad. I'm also turning it into a blue.
Awesome work and a fun build. I'll be watching this one.
John
    August 2005
Posted by Phil_H on Thursday, June 18, 2015 10:17 AM
I suspect that the kit represented one of the prototypes/pre-production aircraft at some stage. These actually did have open slots (boundary layer air discharge slots) in the leading edge extension. They were solid on later aircraft except for a short open section near the intakes.
    April 2015
Posted by UlteriorModem on Thursday, June 18, 2015 4:32 PM
Interisting, thanks for all the responses and input.
Well as you can see it is too late to go back now! LOL
I am nearly done with the putty work. I am not going to do the bottom part as this is just kind of a cast off practice thing anyhow. More pics coming either tonight or tomorrow.
    September 2003
Posted by checkmateking02 on Thursday, June 18, 2015 5:35 PM
Hats off to you for even trying this!
    May 2006
Posted by Rob Beach on Thursday, June 18, 2015 6:47 PM
We've used this kit for Make & Take events and it has some 'sticky' points in the construction.  Plan on using a bit of shim material and glue to get the tails to seat properly.  Bit of 'fettling' of the mating surface will improve the fit.  Not too bad really for a snap-tite kit, though, being as it is fairly accurate (well, does as you noted have some "pre-production" airframe features like the slots...) and has good looking landing gear (but the main wheels need some modification to fit tight & at the correct angles.)  But for the money and a litle bit of work, it is a cheap clothes-horse for that stack of Hornet decals hiding in the corner!
Oh yes, if you *do* use the Blue's stickers, recommend cutting the larger ones into smaller sections & cutting the 'clearance holes' a bit larger.  The adhesive works, well, TOO well & doesn't really let you re-position 'em.  I didn't try the ol' soapy water trick, but it may work in this situation to allow some sliding around before squeezing the water out to bed the sticker down.  But they are awfully thick and so tend to 'ride' above any surface details like panel lines. However, there are a few aftermarket B-A sheets out there if you can find one that would be easier to deal with than these beasties.
That is one thing I really like about the 1/48 WWII range by Pegasus Hobbies - they come with stickers AND waterslide decals.
Have fun, regardless!
Regards, Robert
    April 2015
Posted by UlteriorModem on Friday, June 19, 2015 4:48 PM
    July 2011
Posted by MJames70 on Friday, June 19, 2015 5:13 PM
Good luck on your build. In general, these are pretty decent kits, all things considered.
Here's a tip I have found that sometimes helps on snap type kits. Either remove, or enlarge the holes where the pins fit into the press fit holes. With them removed/enlarged, it is sometimes possible to get a better fit by gluing conventionally with the pins not in the way.
There have been indeed changes to the molds over the years on these kits. The F-14 Tomcat did initially come with landing gear in its early releases, and the mold was converted into its current wheels up-stand configuration.
    April 2014
Posted by B_one fixer on Saturday, June 20, 2015 2:45 PM
Not looking bad at all there
    December 2013
Posted by jetmaker on Sunday, June 21, 2015 12:52 AM
This is a fun little build to watch. UM, I almost bought an EZ-Snap kit today at the LHS because of this thread. I still might...
    August 2013
Posted by Jay Jay on Sunday, June 21, 2015 9:01 AM
This is the very kit my wife wants me to build.
We attended an air show / museum in Melborne Florida and she fell in love with the F-18 Blue Angel they have there.
I appreciate your posts and the heads up etc. by everyone, and now I am prepared to undertake my SWMBO'S request.  so it's off to the LHS to buy the kit and lots of putty.
    March 2015
Posted by Toshi on Sunday, June 21, 2015 9:28 AM
Wow, that's a lot of work for a snaptite.  Still that's a great job you've done to correct any imperfections.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    November 2010
Posted by john087 on Friday, June 26, 2015 9:25 PM
You are using mm acrylic paints. I am about to spray my blue and haven't decided if I want to use the declares for the yellow portion or paint it. How well did the yellow cover the blue?
    April 2015
Posted by UlteriorModem on Saturday, June 27, 2015 2:09 PM
I used MM "Chrome yellow" as mentioned before and it was nearly a dead on match to the decal colors.
The coverage was fine but took 3 or 4 light coats to cover.
But as you saw in the photos I 'forgot' (read lazy) to seal the taping before I applied the yellow and paid the price. If I had it to do over I would treat it with a coat or two of the blue first to pre seal the tape edges.
Good luck!
    June 2014
Posted by BrandonK on Saturday, June 27, 2015 4:31 PM
Wow, that was some crazy gaps. Nice save there. Starting to look like a nice kit. Gotta love the F18.
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    June 2004
Posted by seasick on Saturday, June 27, 2015 11:27 PM
You deserve the distinguished model building cross for this build.
Chasing the ultimate build.
