Different Colored Panels - Oh Yeah !
    August 2008
Posted by tankerbuilder on Thursday, June 25, 2015 12:08 PM
This is what this is all about .I am seeing more and more really great Bare Metal Panels on Planes done with Alclad .  I might try it one of these days . I still do it my way which to some is frightful , tedious and just plain aggravating !
     Yup , I use four or five shades of bare metal foil . usually foil I make myself with the Foil adhesive and four or five sheets of foil from different Dollar type stores and some sheets turned dull side out .
 You see I learned doing car trim that the cheaper the foil the better the burnishing worked .Why ? Well some of the cheap stuff , though very shiny is also very thin and in some cases thinner that B.M.F.brand .
      That said there is a warning I will issue here .If you go to Hobby Lobby because you are on a tight budget , DO NOT buy the Testors foil . It's garbage as far as I am concerned ! It's hard to burnish , The adhesive is to strong and you'll rip your part AND it falls off after about a month or so . Leastwise that's my experience with it ! Looks pretty in the package though and the price is attractive .
    Save your coins and when you can buy one package of B.M.F. Brand at a time while you build .Then when you are ready you have your foil ! OR if you are a really good airbrush painter go for the Alclad . I have only tried it on car Bumpers . It is some cool stuff !
     Or be an old poop like me and make your own B.M.F.
    August 2013
Posted by Jay Jay on Thursday, June 25, 2015 1:41 PM
Old poop my foot.
Your BMF is incredable and I think looks better and more realistic than Alclad, and certainly more impressive.
    May 2008
Posted by MIflyer on Thursday, June 25, 2015 1:48 PM
Question - when you use regular kitchen foil, what do you use for an adhesive? I wouldn't mind giving it a try - foils designed for modeling are so darned fragile.
Kevin Johnson    Ypsilanti, Michigan USA
On the bench: 1/72 Fujimi Ki-36 J-BAAR
