- Member since
October 2004
Posted by Ben Brown
on Monday, July 13, 2015 8:09 AM
I recently finished the Monogram kit. Comparing it with the HB kit, is similar to comparing Monogram's F-100D to Trumpeter's: if you want accurate, go with Monogram, if you want a relatively easy build, with recessed panel lines, go with HB. Contrary to some Internet reviews and drawings, Monogram's nose is actually pretty close to the real thing. I've had the opportunity to compare a built one with a real Thud, and it captures the shape of the nose pretty well. What throws the look off is the radome doesn't mate with the fuselage very well, and the pitot tube is too large and off-center. Replace it with a Master Model brass one, and it completely changes the look of the model. The main gear is a little wiggly, but one I built over 20 years ago and sat on the shelf and survived 2 moves without breaking. There are a few small details that need tweaking, such as some antennae left over from the F-105G kit, and the intakes are a pain in the neck, but overall, it's a pretty good kit.
Ben
