Newb seeking advice on doing filtering of camo with an airbrush
Posted by djrost_2000 on Friday, July 10, 2015 9:52 AM
Years ago I built the Airfix 1/72 Su-27 but I was not satisfied with the way the camo turned out. There was basically too much contrast between the different shades and it didn't look like the Flankers in my photos. I've got another Flanker I'm building and thinking of doing a quick pass filter with my airbrush to better tie the shades together. Seeking some basic advice on how to do this. Do I mix a little of all three shades together and give it a quick pass with my airbrush? Thank you, Dave
    April 2010
Posted by Mustang8376 on Friday, July 10, 2015 10:24 AM
Are you trying to use a soft edge or hard edge camo scheme?  I've found doing a camo scheme soft edge toned downt he contrast a bit.  Also, you can lighten the colors for scale effect.  Other's with more experience will chime in I'm sure.
Current build: 1/48 Monogram A-1H & AMT Jedi Starfighter.
Completed:  1/48 Monogram/Revell P-61B, 1/32 Hasegawa F6F-5, 1/48 Hasegawa F-16C, 1/48 Revell Mig-21PFM, 1/48 Revell/Monogram AH-64A, Revell/Monogram 1/48 F-14D, AMT 1/420 USS Defiant, AMT 1/650(?) USS Enterprise, 1/72 Bandai VF-1J, AMT 1/537 USS Reliant, Academy 1/35 M1-A1 Abrams, Academy 1/48 F-86F30, Linbergh's USS Gato
    June 2014
Posted by BrandonK on Friday, July 10, 2015 11:21 AM
I use silly putty to mark my color demarcation lines. Don't paint down into the edge, but rather straight on to the surface. This causes the paint to feather down from where you are spraying and into the edge of the putty, which is not in line with the airbrush. In a sense you are over spraying the demarcation to give it a soft edge you see on the real planes.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
Posted by Gamera on Friday, July 10, 2015 11:38 AM
If doing a filter you'll want it very thin, almost like tinted thinner. Probably something like a light tan on a green/brown plane or light grey on a grey plane. Build it up slowly with multiple light passes until it gets almost where it looks perfect and then stop and let the thing dry and look over her for a day or two. You don't want to go too far since you can't take it back once done- but you can always add an extra layer or three if you don't think you added enough.
Posted by djrost_2000 on Friday, July 10, 2015 11:42 AM
Ok, on the previous Flanker the shades might have been too dark to begin with and I think I might have used straight masking tape.  I have silly putty and planned on a softer edge camo scheme.   Maybe these will help?
Thanks for the replies,
Dave
Posted by djrost_2000 on Friday, July 10, 2015 11:47 AM
Thank you Gamera!  I think I got the jist of it.  I think I'll airbrush with lightened tones and silly putty and if that still doesn't do it will try a blue/gray filter.
Thanks
    April 2010
Posted by Mustang8376 on Friday, July 10, 2015 1:26 PM
Some of the articles from Finescale were a lot of help. Here's and example of using poster tac and a cut paper pattern.
    June 2015
Posted by jezz on Friday, July 10, 2015 3:11 PM
This was my attempt at poster tac and a few light passed with lightened base colour worked from the centre of the panels to give a bit of depth
Posted by djrost_2000 on Friday, July 10, 2015 5:12 PM
Like and Like
    June 2014
Posted by BrandonK on Friday, July 10, 2015 9:55 PM
Look for tips and videos. Then it's just trial and error till you find a method that suits your style. Good luck with it.
BK
On the bench:
                         14 / 5 / 2
                              Tongue Tied
