Jayjaye prime the parts u are painting yellow with white or mix some yellow with white as a base then i preshade the panel lines first you can use a red brown or grey not to heavy then i used for this kit humbrol enamel lemon yellow( i dont normally use enamels ) with it thinned out really thin.i then slowly build up the color starting by airbrushing with a dual action revell airbrush paint only the centre of the panels blending it softly to the edge of the preshaded area try not to spray over too heavy or quick the slower the build up the better patience if key here repeat the prosses as until u are happy with the finish
Then once fonishe i spray jhonsons klear to seal ready for oil wash in panel lines then wipe clean wuth soft cloth wipe in the direction off the airflow leaving
Also i just ordered the revell 1/48 kingfisher and the B-25
