Yellow woes...
    September 2013
Yellow woes...
Posted by AdeB on Saturday, August 22, 2015 4:02 PM
Ok everyone, having issues finding a decent Yellow acrylic to airbrush.
Recommendations?
    November 2003
Posted by mississippivol on Saturday, August 22, 2015 4:23 PM
None. I have problems with the enamels as well. Best way is white primer followed by light coats built up to when you like it.
    May 2013
Posted by Greg on Saturday, August 22, 2015 5:14 PM
So far, I have found Tamiya XF-3 Acrylic Flat Yellow to be the best covering and spraying yellow I've ever used.
And I'm primarily a Vallejo guy.
My 2 cents anyway.
Posted by jeaton01 on Saturday, August 22, 2015 11:44 PM
Yup, white undercoat and Tamiya flat yellow.  Use a gloss clear if you need gloss.
John
    September 2013
Posted by AdeB on Sunday, August 23, 2015 2:24 AM
Thanks guys, unfortunately XF-3 is one I'm still having issues with...I shall persevere.
Although I have actually found it seems to go on better over a matt back base...oh well.
    April 2004
Posted by Jon_a_its on Sunday, August 23, 2015 3:09 AM
Hannants Xtracrylics Trainer yellow spray well & is tough, but not bright yellow.
East Mids Model Club 32nd Annual Show 2nd April 2023
 http://www.eastmidsmodelclub.co.uk/
Don't feed the CM!
    January 2012
Posted by scapilot on Sunday, August 23, 2015 3:32 AM
Yellow is easy with a primed white background. Easy on the application and you should be fine.
Posted by rangerj on Sunday, August 23, 2015 9:16 AM
Yellow over a silver or aluminium base also works well.
Posted by Don Stauffer on Sunday, August 23, 2015 12:32 PM
I find in either acrylic OR enamel, yellow is about the hardest color to cover evenly.  Like most of you, I always use a white primer under yellow, even if I started with a gray, thick primer to cover seams and sink marks.
    October 2004
Posted by Allen109 on Sunday, August 23, 2015 1:58 PM
Its gotta be better than the Testors Acryl RLM 04;always comes out with a pronounced orange tint.
    June 2014
Posted by BrandonK on Tuesday, August 25, 2015 9:06 AM
I began using the Mr Color yellow due to the same reasons you mentioned. The Mr Color paints tend to be less transparent than Tamiya paints. They are generally thicker. But you still need to prime white underneath.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    January 2013
Posted by BlackSheepTwoOneFour on Tuesday, August 25, 2015 11:36 AM
rangerj
I second that suggestion. Try spraying in several light coats until you achieve the desired coverage to your liking.
    October 2007
Posted by Milairjunkie on Wednesday, August 26, 2015 7:18 PM
I'll third the silver method.
    September 2013
Posted by AdeB on Friday, August 28, 2015 3:41 AM
Cheers again! I am currently building (another) Tamiya P51. Be onto the prop tips very soon so I shall let you know how i get on.
    September 2006
Posted by the Baron on Friday, August 28, 2015 12:29 PM
AdeB
Can you describe the issues you're having? Reading the previous posts, I can see that we all thought of the same thing, and that the issue you're having is getting a good, solid, bright yellow.  That's the point of priming with white, it will make the overlaying yellow coat brighter (same goes for red, by the way).  A dark primer will impart a dark shade to the overlaying color.
But we're assuming that's the problem.  Since you mention Tamiya's XF-3 (which I also use), is it the color and how it looks when you're finished, or is the problem in applying it, it doesn't flow well through the airbrush for you, for example, or some other problem?
I have also used craft store acrylic (Americana), applied with an airbrush, and got a good color finish.  There was a technical issue, in that craft store paints generally have coarser pigments than paints formulated for scale modelers to use, so there was some clumping, and when the paint dried and cured, it had a rougher surface, which I knocked down by rubbing with a piece of an old T-shirt.
