What are people using as a base & accs. for 1/32nd scale aircraft dioramas?
    February 2015
Posted by panzer948 on Friday, October 16, 2015 12:05 PM
I am thinking about creating a small diorama to set my (now WIP) JU88-A1 on display.  Nothing to elaborate of a scene. Probably just show the parking area off of the taxiway/runway typical of German airbases from that period.  I may not even include figures. Not sure if that could be concrete or dirt covered. If concrete, do they have any aftermarket stuff in 1/32 scale to depict tarmac?  If dirt, I will likely just make that using celluclay.
What are the general thoughts of using some 1/35 scale accessories in a 1/32nd scale dio?  I have a tone of metal boxes, crates, fences, animals etc. that I could use.  But would that be too obvious.
On the bench: Revell 1/32nd Junkers JU-88 A1
    May 2009
Posted by Pawel on Friday, October 16, 2015 12:46 PM
Hello!
Fine sanding paper makes a great tarmac if it's the right colour - I mean anything from black to grey could work here. Add some spills, tar painted with gloss black paint and some vegetation - static grass, moss and you should be good to go. A bucket, a jerry can or maybe a bicycle could add interest - and those can be had in 1/35 - I'd say close enough. I hope it helps - good luck with your project and have a nice day
Paweł
www.vietnam.net.pl
Posted by Bish on Friday, October 16, 2015 1:15 PM
ye, I think I would go with fine sandpaper. there are printed bases, not sure about in 32nd scale, but that are very flat and smooth. I do plan on doing any of my 32nd builds as dio's as I do with my 72nd, but I will put them all on bases and a few will need tarmac and sand paper is what I am considering.
    February 2015
Posted by panzer948 on Friday, October 16, 2015 1:39 PM
Great idea with sandpaper. Do you guys know of some images or WIP on forums of someone that has already done this? I am curious how they did the edges and if they added any paint besides the weathering effects.  Also, I would think you would need to recreate the expansion gaps somehow that they usually add between the sections of concrete. But yeah that has me thinking...
Posted by Bish on Friday, October 16, 2015 1:56 PM
panzer, not sure about the edges, as I have only done this in 72nd and I put an edge around the board. But in 32nd I plan on doing it different. For the expansion joints I cut lines into the base. I have checked out images of relevant aircraft to get the size of each panel, only a rough guess of course. Pnce the lines are cut, I paint in with black artists acrylic. You could use oils as well. Its time consuming but the effects are nice.
Here is a couple of examples, again they are 72nd.
This is my only 32nd one so far. Its on sand, but i plan on doing the tarmac ones similar, and i am guessing this is what you have in mind. As mentioned, i have yet to work out what i will do with the edges, maybe black paint.
    February 2015
Posted by panzer948 on Friday, October 16, 2015 2:20 PM
Great stuff. I checked out your other dios on photobucket too for other ideas. I especially like the one you did below (hope you don't mind me sharing it here with others). That is what I meant by edge as I was thinking of a sceneario where the edge of the tarmac/concrete hits a section of natural terrain with soil/grass.  I am curious how large the tarmac concrete section (German tarmac for that matter) should be in 1/32 scale.  But yea love your work.
Posted by Bish on Friday, October 16, 2015 2:51 PM
Nope, don't mind at all. While most of my concrete ones are all concrete, the ones with the grass do look much nicer.
In 72nd scale I do the German panels at 8 by 14cm. So if I have worked that out right, in 32nd that's 18 by 31.5. But again, that was a rough guess by looking at aircraft on tarmac and comparing the edge of the panels with parts of the aircraft. But each nation and period will be different. But that should work for your 88.
Posted by Bish on Friday, October 16, 2015 2:59 PM
I should point out that for those 72nd builds I don't use sandpaper, I think it would be to rough. I use cardboard, and I have a ready supply. The inside of kit box lids and the rough side of the cardboard inserts that come with Eduard PE sets have the ideal texture for this scale.
    September 2005
Posted by richs26 on Friday, October 16, 2015 10:24 PM
Bish
Bish, if I remember correctly from my USAF Rapid Runway Repair (RRR) days at Ramstein AB, Germany from -87 to -92, postwar German concrete is poured 10 meters on a joint.  I believe US pours use 10 feet on a joint.  I will have to look on Youtube for any 80's Local Salty Demo videos of the RRR repairs of the Spangdahlem runways and taxiways to be sure.
WIP:  Monogram 1/72 B-26 (Snaptite) as 73rd BS B-26, 40-1408, torpedo bomber attempt on Ryujo
Monogram 1/72 B-26 (Snaptite) as 22nd BG B-26, 7-Mile Drome, New Guinea
Minicraft 1/72 B-24D as LB-30, AL-613, "Tough Boy", 28th Composite Group
Posted by Don Stauffer on Saturday, October 17, 2015 9:30 AM
Check the model railroading section of your LHS.  They have neat things for ground cover and pavements.  I especially like those mats of grass, though I think they are too fine a texture for 1:32- fine for 1:48 and smaller.  Still, they have various stuff that WILL work in larger scales- just not as handy to apply.  Weeds, flock type grass, gravel, etc.
Posted by Bish on Saturday, October 17, 2015 10:03 AM
Don, the problem with many of the mats I have seen is that they are to uniform, like well kept lawns. There are some new ones out that have bare patches, stone sand so on, but they are damn expensive.
    May 2009
Posted by Pawel on Saturday, October 17, 2015 10:27 AM
Bish - that's true, out of the box, or, to say it better, off the roll, those mats look better than a golf course or queens lawn, but you can easily mahe them more realistic by sprinkling on some other grass stuff - static grass, coloured sawdust, almost anything. Spraying a random squiggles of different shades of green also helps a lot. Here's what I made using those techniques in 1/35:
1:35 M55 Quad 50 diorama by Pawel
Hope it helps - good luck with your builds and have a nice day
Paweł
www.vietnam.net.pl
Posted by Bish on Saturday, October 17, 2015 10:34 AM
That would help Pawel, but the problem with aircraft being on grass is that with the aircraft taxing, lots of people and vehicles moving around, it tends to leave bare patches. So you would have to pull some of it out. But for grass at the side of concrete strips or hard standings, I think they would work fine.
Posted by Don Stauffer on Sunday, October 18, 2015 11:08 AM
Bish
My LHSs carry two grass mat styles, one with just a uniform green, the other more mottled with shades of yellow and tan, though they are all uniform height.  One could add taller weeds to the mottled ones, however, and that looks better.  If it is an active field, they probably mow it occasionally.  A crash in a field certainly needs other vegetation.
    September 2013
Posted by AdeB on Monday, October 19, 2015 4:53 AM
Picked up these plain bases fom EBay for £5. Just added a bit of dirt and scatter...took about 10 mins to knock up. The dirt was fixed using white PVA glue which had an unexpected side effect. I thought I'd over done it on a few places but it kinda dried "wet looking" as you can see. Looks like soggy ground.
