XP-47H WIP
XP-47H WIP
Posted by Don Stauffer on Friday, December 18, 2015 12:01 PM
Here is a shot of my XP-47H project.  The fuselage is vacuform, from KAE.  I will be using a Revell P-47 donor kit for wings, horizontal tail, and various details.  This shot shows a keel I put into vacuform models.  It is 3/16 basswood. It provides a flange for easy gluing of the fuselage shells together, eliminating the need to glue the thin shells together in a butt joint, and strengthens the fuselage greatly.
The areas painted black on the keel are areas where openings like cooling vents or exhaust stacks will be placed on the outer shells, and prevents seeing the keel through these openings.
    June 2014
Posted by BrandonK on Friday, December 18, 2015 2:19 PM
That's too cool. Looking forward to see this come together.
BK
On the bench:
A lot !! And I mean A LOT!!
                         14 / 5 / 2
                              Tongue Tied
    March 2015
Posted by Toshi on Friday, December 18, 2015 2:32 PM
Wow, I've never seen anything like this before.  Looking forward to this build.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
GAF
    June 2012
Posted by GAF on Friday, December 18, 2015 2:56 PM
Don,
That's a nice trick on the "keel".  I've wondered how vac-u-form moldings could be put together securely.  Yes
Gary
    January 2015
Posted by GreenStyrene48 on Friday, December 18, 2015 3:39 PM
Excellent.  I'll be following your progress.  I'm building the XP-72 right now.  I used the procedure from the instructions about using little plastic tabs to secure the fuselage.  I had to file an angle on some, especially along the keel, so the halves would fit well.
Posted by jeaton01 on Friday, December 18, 2015 5:29 PM
Good idea, Don.
John
