Hasegawa 1:32 A6M5c, or a comedy of errors
    December 2015
Posted by templar1099 on Sunday, March 13, 2016 1:28 PM
I am really looking foward to posting a finished subject with less problems, but posting nonetheless. I was expecting a little bit of a better kit being from Hasegawa, but what do I know. I know it is an older release and will be able to judge better when I get a newer model to compare. First off it wasn't a matter of excess flashing so much as too much " over hang" foward and not enough coverage rearward on the wings, if you get what I mean. All round misalgnment, tail included. The canopy was flimsy with virtually no indent to help with masking and the decals were the worst. Most are literally pieced together and I had to paint the bottom Hinomaru as they would not release from the backing. ( I will say that painting such markings if done properly certainly beats the best decaling.) HOT water and a little detergent helped save the rest but they could not be moved once laid down without fracturing and they all silvered regardless of solvent used. I also found that the supplied "suggestions" were sketchy at points, in particular the engine construction, which must be aligned just so to get it all to properly fit together.
On to self inflicted wounds, as always the wing antenna was the first to go, followed by the port side landing gear which now lists foward and outward. Due to illness the canopy remained masked for too long I guess because eveything I did to try and clean it up just made it worse. I had sealed the burnished edges of tape with liquid mask to compensate for the lack of an edge and that just turned out to be a case of out-thinking myself. No amount of cleaning,sanding and polishing made a real difference so I left well enough alone. Even the adhesive from the tape left tell tale residue. As to the paint scheme I mixed what I had on hand with the 'suggestions' ratios and settled for what I liked. It is what it is.
http://i628.photobucket.com/albums/uu8/dagobert1/fsm/DSC03990_zpsc6qoujq2.jpg
http://s628.photobucket.com/user/dagobert1/media/fsm/DSC03994_zpsjn2gpmf0.jpg.html?sort=3&o=0
http://i628.photobucket.com/albums/uu8/dagobert1/fsm/DSC03973_zpssj3gyokd.jpg
"le plaisir delicieux et toujours nouveau d'une occupation inutile"
Posted by Gamera on Monday, March 14, 2016 7:47 AM
Yeah, it's not a newer Hasegawa kit, I think it dates back to the '70s maybe late '60s even. Both Hasegawa and Tamiya still keep some older kits in production and well, they ain't anywhere near their modern standards. Most are pretty decent though, wonder if you got a bad kit.
And if the box is old the decals are probably bad, I don't really like Hasegawa decals anyhow and usually try to replace them. She didn't turn out half bad otherwise. I wonder at some of your more unusal colour choices, did you find references to these? Not knocking you but the brown cowling and red leading edge stripes I've never seen before.
    December 2015
Posted by templar1099 on Monday, March 14, 2016 11:37 AM
Thanks Gamera, yea the cowling was a mind flub on my part,painting the prop red/brown as called for. I got sick as a dog with this bug and by the time I felt good enough to get back and finish, went right by it. The ID stripes on the wings called for an orange/yellow with some references saying more to the red and some more to the orange. Depending on the light it appears more orange to my eyes. The fuselage colors were, top:50% blue,45% green, and5% yellow, bottom:70%white,10%brown,10%black,5%yellow and 5%yellow. Like I said I mixed what I had on hand and settled on the grey/green and then lightened by about 2 shades for the bottom. The disagreements on the colors of the zero are fodder for enthusiasts, went with what I liked.Zero Camouflage Schemes by James F Lansdale is what I basically used for reference.Bad kit or bad practitioner?
Posted by Gamera on Monday, March 14, 2016 12:03 PM
Ah ok, maybe it's just my eyeballs that need to be recalibrated. Blind Fold
She don't look half bad in the photos but still I know what you mean about some kits just seem to want to screw up at every juction. Sometimes you just have to call the thing a learning experience and move on...
Posted by Ashley on Monday, March 14, 2016 4:35 PM
All in all, a great looking build, in spite of getting excess lip from the kit! The prop color looks spot on to me, and we can always say the cowl is a field repair and they didn't have any of the correct color! It actually looks good. As far as the leading edge stripes go, they are going to look different in various lighting, and even digital photos can shift the color somewhat. I think Zeke looks great!
Have you flown a Ford lately?
    December 2015
Posted by templar1099 on Monday, March 14, 2016 4:43 PM
Thanks Ash, I was looking forward to that kit and didn't want it to totally slip away from me. On to the next one.
    March 2015
Posted by Toshi on Wednesday, March 16, 2016 4:57 AM
With all the issues and concerns, you overcame them and you've a fantastic build here.
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    September 2010
Posted by mikeymize on Wednesday, March 16, 2016 9:18 AM
   As others mentioned, I think the reults are pretty good given the circumstances under which you laboured. I've had kits that gave me problems as well and simply use them as a learning experience, rather than getting too upset. I'd say, on balance you should be proud of the results! Thanks for the insights on this kit and I'll keep in mind to avoid attempting this one!
"Time you enjoy wasting is not wasted time".
    December 2015
Posted by templar1099 on Wednesday, March 16, 2016 10:37 AM
Once again, thanks Tosh, onward and upward.
    December 2015
Posted by templar1099 on Wednesday, March 16, 2016 10:39 AM
Thanks mikeymize, what ever doesn't kill us.... just leaves us wounded.
