This year I finished Revell's 1/48 scale B24 and B17. After Summer I intend to build Revell's 1/48, B29 in a natural finish using Bare-Metail foil as a final finish. I never used metal foil as a finish material, so I thought that I would give it a try on a smaller and cheaper airplane before I tried it on the B29.
I have decided to use Revell's P47N as my first try at using metal foil. HOWEVER, the instructions require that the landing gear be attached before the wings are glued together. This is nuts because there is a good chance that the landing gear will get broken off during the remainder of the build. Has anyone developed a procedure for installing the landing gear after the wings are glued together?
Thanks in advance.
