1/48 F-105 : Monogram vs. Hobbyboss
    August 2014
Posted by Timdude on Friday, March 25, 2016 9:51 AM
I have a rather large cache of Monogram F-105s waiting to be built. I have seen some builds here on the forum about the Hobbyboss kit. Looking arould on ebay there seems to be a lot of AM "fix it" kits for the HB and only basic (cockpit and gunbay mostly) for the Monogram. I have heard said that the HB kit is well detailed but the gear is questionable.
So, my question is: how do the two kits compare with each other. Accuracy? Detail? Problems? Any other points to be made between the two kits?
My plan is to build at least one of each variant. I have a resin nose for a B. I will have to rescribe the panel lines for that one. I also have the resin T-stick conversion. Is there any advantage of the new kit, Revell I think, over the conversion?
Thanks, Tim
    November 2003
Posted by mississippivol on Friday, March 25, 2016 10:31 AM
You will have gear issues with either kit, it's the nature of tall gear and injection molded plastic. I'd stay with the Monogram kit, raised panel lines isn't the end of the world.
    August 2015
Posted by crown r n7 on Friday, March 25, 2016 11:05 AM
I agree with mississippivol
 Nick.
    March 2010
Posted by Nathan T on Friday, March 25, 2016 11:18 AM
Depends if you want raised or recessed Lines, simple as that. The HobbyBoss kit does fit better overall
    August 2014
Posted by Timdude on Friday, March 25, 2016 12:05 PM
I was planning to use metal gear on either one.
    November 2003
Posted by mississippivol on Friday, March 25, 2016 9:00 PM
Good call.
