Ju87D-3 1/48 Hasegawa
    August 2009
Posted by TREYZX10R on Tuesday, May 17, 2016 5:11 PM
This started out as a fun destress build,turned into a struggle. I'm geussing this kit suffers fit issues by offering multiple versions of the airframe rather than retooling for each one. I get that, but each sub component needed filler,making for a lot of tedious sanding and rescribing. When I joined the wing to the Fuse I was impressed that it did'nt need any filler,especially after all the other bits did. My enjoyment was short lived as the port wing tip was 1/4 inch high. My fault for getting excited about the great fit and glueing the area before checking . I did find a work around without destroying the wing/root area. I used a razor saw and carefully cut along the seem at the wing bend , secured the wing ,pulled the tip down to the correct height and then filled the razor saw cut with thin Ca glue . I kept the weathering very light ,model master enamels followed with Testors Dullcote finished it off. The decals layed down nice after some Solvaset . The markings are for 2/NSGr.9 Italy 1944 . Thanks for looking cheers Trey
    August 2013
Posted by Jay Jay on Wednesday, May 18, 2016 8:15 AM
GEEEZOW what a gorgeous build !  Ty for posting Mate.
    August 2009
Posted by TREYZX10R on Wednesday, May 18, 2016 12:27 PM
Thanks for the kind words Jay Jay,appreciate you taking the time to comment.
    May 2013
Posted by hogfanfs on Wednesday, May 18, 2016 12:43 PM
It looks fantastic! You overcame the issues you had with flying colors. Great job!
 Bruce
 On the bench:  1/48 Eduard MiG-21MF
                        1/35 Takom Merkava Mk.I
    August 2009
Posted by TREYZX10R on Wednesday, May 18, 2016 12:56 PM
Thank you kindly Bruce,much appreciated!
Posted by Bish on Wednesday, May 18, 2016 2:18 PM
MMMMMMMMMMMMMM, Stuka. Nice job TREY.
I am curious about what you said about the fit issues. There should not be any major differance between the versions that would use this airframe. From the D-1 to the G's, it was pretty much the same apart from extra armour. Could just be poor mouldings. Not good news as i am thinking of getting their 48th G-2.
    August 2009
Posted by JOE RIX on Wednesday, May 18, 2016 4:03 PM
Now, that there is one dandy of a Stuka. Excellent work Trey. Your splinter camo is especially well done. Appears to me that you overcame any fit issues brilliantly. Thanks for sharing your Stuka with us.
"Not only do I not know what's going on, I wouldn't know what to do about it if I did". George Carlin
    March 2015
Posted by Toshi on Wednesday, May 18, 2016 5:24 PM
JOE RIX
This is a fantastic example of a build that's done right!  The Stuka reminds me of the F4U Corsairs wing.  Another great job sir!
Toshi
On The Bench: Revell 1/48 B-25 Mitchell
Married to the most caring, loving, understanding, and beautiful wife in the world.  Mrs. Toshi
    December 2010
Posted by 1943Mike on Wednesday, May 18, 2016 6:31 PM
Razor saw! That's like major committment to the operating table Big Smile. I can't see the scar.
Seriously, really fine work.
I'm not that familiar with the different kits of 1/48 Stukas. I have the Hase Ju87B-2 which I'll get to probably next year and, even if it doesn't have any issues, I'll be happy to have it turn out anywhere near as nice as your build.
"Le temps est un grand maître, mais malheureusement, il tue tous ses élèves."
Hector Berlioz
    August 2009
Posted by TREYZX10R on Wednesday, May 18, 2016 7:21 PM
Bish
Thanks Bish ,The front scoop was molded seperately and you can see how much filler it took on the pic with the interior. I figured that maybe there was a slight variation in that on another version of the D or G ? The upper fuse to forward cowl has a seperate panel with fit issues as well ,but do'nt see a need for it to be molded seperately? Real head scratcher for sure.
    August 2009
Posted by TREYZX10R on Wednesday, May 18, 2016 7:24 PM
Joe ,Toshi thank you both for the compliments
Mike the thin ca glue wicked in to the cut so nice it was just a few swipes of sandpaper to blend it. Since there is a raised bit along the cut it worked to my advantage. Thanks for the kind words.
Posted by Bish on Thursday, May 19, 2016 12:33 AM
TREYZX10R
Bish
Given the issues are at the front, it sounds like the main fuselage is shared with the B kits.
    August 2009
Posted by TREYZX10R on Friday, May 20, 2016 8:50 PM
Bish
TREYZX10R
Bish
That would be my geuss as well, sad because the rest of the kit is nicely done,rivet detal.panel lines ect.
